Threads: 29
Car Model/Spec: 306 2.0 8v Turbo
Can anybody help me out here, Trying to seperate the gearbox from the engine i have bought. For some reason i cannot get the box off, all the bolts are out and the wiring is clear, is there anything that i have missed, its as though the release bearing is stuck to the pressure plate. I dont have a manual so i am working blind. Dont want to start levering and tickle sticking if there is a simple solution.
1999 2.0 8v Turbo 306
You Tube: 832 Performance
Threads: 29
DOH !!!!!!! Take it you have to knock the retaining pin out of the arm in order to release it.
Threads: 465
114
Car Model/Spec: Vauxhall
mine had a spring retaining clip removed that, then pulled the pin out with mole grips, then worked the lever off the shaft
Threads: 29
Cheers Cully, all sorted, took the clutch arm off and it slid straight out. Many thanks
