Rear Shockers
Hi Guy's. I presume rear shockers are the same across all the 306 models but as I don't like to rely on presumptions I thought I'd ask you guy's to confirm.
The reason I ask is I've found these and as I am needing mine replaced on my HDI thought I might give them a bid.
http://www.ebay.co.uk/itm/Peugeot-306-GT...27d6c87c63
yeh they'll be fine ThumbsUp
Thanks Ginge!
note; you'll need bolts; guessing if you're just swapping them, use your existing bolts ThumbsUp
If they don't snap removing them, they look like they've been there since the car was born lol
lol they won't snap
they shouldn't anyway, i've never had any snap; bloooody tight, but never snap lol
(28-08-2013, 02:43 PM)ginge191 Wrote: lol they won't snap
I've never had a hub to strut pinch bolt snap on me till this car lol
da fuq; a snapped pinch bolt!? lmao
In that case, good luck! :
Best to get a new nut, only from Pug though.
(28-08-2013, 02:47 PM)ginge191 Wrote: da fuq; a snapped pinch bolt!? lmao
Yeah what a job that turned into lol.
(28-08-2013, 02:52 PM)Bender Wrote: Best to get a new nut, only from Pug though.
I'll grab now nuts and bolts from Pug before I do the job just in case.
Great, as long as it has a new nut thats the main thing and wont hurt getting the lot. However afair pug no longer sell the bolts just nuts now.Sad
I'm sure I could pick some high tensile bolts up if I knew the size. Like to be prepared as everything seems seized solid on this car grrrr
Nope I tried that and they are a weird size a nut n bolt place could not match, ie head is where it wedges into the recess in the arm. Im sure you can find something to wedge the smaller head.
Are they all nylon locking nuts on the rear beam?
Almost, the rear mount bolts to body are washer nuts same as the front OS engine mount bracket ones but I use nylon just in case. All the others are nylon ones.
The bolts are still available from Pug as i got all new ones not that long ago when i replaced my rear shocks.
They must have got a load made up then or they found some, they are well known for taking their time in producing bolts etc, like the torsion bar shouldered bolts a while back took over a year.
  wrong shockers? 318d4n 3 2,826 26-09-2012, 09:14 PM
Last Post: Niall
