25-08-2013, 06:02 PM
How easy is it to smooth a boot? And is it best to get to get it welded were the boot lock/pop used to be?
smooth boot
25-08-2013, 06:06 PM
Make sure its a ph3 boot mate otherwise youll get a massive rust bubble under the rubber seal like mine has :/
25-08-2013, 06:51 PM
Im looking into this.
Deffo get it welded. Much better. My problem is the popper and how to wire it in. I can remember dum doing a guide for this but he just used bubbly gum to fill his hole. But hey if it works then it works.
25-08-2013, 06:53 PM
just need a centrol locking servo motor, earth it, and then run a positive feed to it from a switch inside.
25-08-2013, 11:04 PM
(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. One sat at mine with popper just needs painting.
26-08-2013, 06:56 AM
(25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. Ill have it mate. 100%. How much?
26-08-2013, 08:54 AM
(25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. I was going to have that off you? You didn't reply to my question about collection?
26-08-2013, 08:59 AM
Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
26-08-2013, 11:18 AM
Mine was welded, I can't take credit for it, but I did wire up the popper, much easier than you'd expect, probably took less than an hour and that included running a signal wire from the boot hatch, down the C-pillar and to the control panel on the drivers side of the car. Hook it up to permanent live though, or you have to f*ck about turning the ignition on to open your boot.
26-08-2013, 03:21 PM
(26-08-2013, 06:56 AM)kingy Wrote:(25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. Pmd (26-08-2013, 08:54 AM)DazzaHDI Wrote:(25-08-2013, 11:04 PM)kentiiboii Wrote:(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this. Sorry mate just checked my pms back till last year havnt seen anything but sorry
26-08-2013, 10:11 PM
(26-08-2013, 03:21 PM)kentiiboii Wrote:(26-08-2013, 06:56 AM)kingy Wrote:(25-08-2013, 11:04 PM)kentiiboii Wrote: One sat at mine with popper just needs painting. YHPM http://306oc.co.uk/forum/thread-15083.html
29-09-2013, 11:29 PM
you could also just use some fiberglass from behind to hold a metal plate in place then a little skim of filler on the outside
30-09-2013, 07:29 AM
(29-09-2013, 11:29 PM)306newbie Wrote: you could also just use some fiberglass from behind to hold a metal plate in place then a little skim of filler on the outside can't see the benefit of fibreglassing a piece of metal in to only fill/skim over when you may aswell just fill over the fibreglass!? Wishes for more power...
30-09-2013, 08:10 AM
there is a guide. just put the popper on the rear wiper wiring. best and easiest way really!
