smooth boot
smooth boot
How easy is it to smooth a boot? And is it best to get to get it welded were the boot lock/pop used to be?
Make sure its a ph3 boot mate otherwise youll get a massive rust bubble under the rubber seal like mine has :/
Mine is a phase 3 chap Smile but ill keep that in mind chap
Im looking into this.
Deffo get it welded. Much better.
My problem is the popper and how to wire it in.
I can remember dum doing a guide for this but he just used bubbly gum to fill his hole. But hey if it works then it works.
just need a centrol locking servo motor, earth it, and then run a positive feed to it from a switch inside.
(25-08-2013, 06:51 PM)kingy Wrote: Im looking into this.
One sat at mine with popper just needs painting.
Ill have it mate. 100%. How much?
I was going to have that off you? You didn't reply to my question about collection?
I did a guide a while ago. It wasnt welded, but it never budged and inch.
clicky
Mine was welded, I can't take credit for it, but I did wire up the popper, much easier than you'd expect, probably took less than an hour and that included running a signal wire from the boot hatch, down the C-pillar and to the control panel on the drivers side of the car. Hook it up to permanent live though, or you have to f*ck about turning the ignition on to open your boot.
[Image: Sig500x130.png]
Pmd
Sorry mate just checked my pms back till last year havnt seen anything but sorry
(25-08-2013, 11:04 PM)kentiiboii Wrote: One sat at mine with popper just needs painting.
Pmd
YHPM
http://306oc.co.uk/forum/thread-15083.html
you could also just use some fiberglass from behind to hold a metal plate in place then a little skim of filler on the outside
(29-09-2013, 11:29 PM)306newbie Wrote: you could also just use some fiberglass from behind to hold a metal plate in place then a little skim of filler on the outside
can't see the benefit of fibreglassing a piece of metal in to only fill/skim over when you may aswell just fill over the fibreglass!? Undecided
there is a guide. just put the popper on the rear wiper wiring. best and easiest way really!
