Threads: 448
51
Been trying a lot of different fuels and mixes recently.
My favourite at the moment is 50% veg 30% diesel 15 % waste oil 5 % petrol.
Car runs nicely on this.
Have you found a certain mix which makes your car run better? Sound better? Or perform better?
Threads: 591
54
100% diesel it runs and sounds and performs very well!
I try loads of different mixes depending on what I am using as my veg...my latest is tescos veg oil, rapeseed.
I managing to get it at about 90p a litre with vouchers so I am living with that.
95%rapeseed.5%petrol with a 50:1oil mix. runs and starts a dream. no flat spots
Threads: 28
3
Given 1 thank(s) in 1 post(s)
I usually run 80/20 WVO/misfuel, which usually results in 80/10/10 or there abouts WVO/diesel/petrol. Depends on the blend of the misfuel, I test it with a hydrometer first. Some batches are nearly all diesel! I also treat my batches with 2-ethylhexyl nitrate (cetane booster).
Threads: 87
48
yeah just a bit of petrol to thin it tbh and maybe a bit of 2 stroke or engine oil, depends what's kicking about . .
Threads: 465
114
Car Model/Spec: Vauxhall
free misfuel / white spirit / old engine oil FTW on my old 106
off road running of coarse as its ileagal to run tied oils as fuel
Threads: 541
124
100% Sunflower oil smells best
Threads: 591
54
I found cetane booster became a waste of money.
did a couple of full tank tests with/without.
Threads: 28
3
What additive were you using Piggy? I was sceptical it would do anything, but I've been using it 2 years now. Cold starts in winter are definitely improved, and I do think the car runs better. Indeed there are research papers that demonstrate the difference a cetane booster can make. The overwhelming opinion veggie forums is that it worth the money, and getting those guys to spend money on anything is very difficult! All in all it costs less than 1ppl anyway.
Threads: 591
54
cant remember was over a year ago I stopped using it.
was just too much faff for me when I couldnt see the benefit.
I should look into it again as I know theres been a couple new boys on the block.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
ten litres of diesel and a bottle of stp, didn't like it at first, but f*ck me i think it's gained another 15hp!!!*
*figure may or may not be accurate/sarcastic
Threads: 41
12
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
Threads: 130
82
Dave, do you bother filtering yours?
Threads: 28
3
These off the shelf cetane boosters probably are a waste of time. The active ingredient is 2EHN but it's usually there in a low concentration. Try some big boy cetane booster
http://www.trinity-research.co.uk/produc...ucts_id=49
Threads: 171
46
Misfuel? Where would one go about getting this?
I guess its just fuel that has been contaminated or something?
Threads: 28
3
It's fuel drained from a car that has had the wrong fuel put in it. A guy that runs recovery trucks lets me help myself as it costs him £50 a drum to get rid of. While a 50/50 blend is actually difficult to ignite, I would urge some common sense when handling the stuff. I only take what I need, use an all plastic pump to transfer, and keep it in sealed HDPE containers. I blend it with the WVO at the nearest opportunity so it isn't lying around. I let it settle then filter straight to 1 micron, it makes filtering so much easier.
Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
(22-08-2013, 04:58 PM)cully Wrote: free misfuel / white spirit / old engine oil FTW on my old 106
What Fuel pump was you doing this on?
Threads: 163
53
Car Model/Spec: 406 HDI
100% rapeseed at 98p a litre, no starting issues and pulling as well as it was on diesel
Threads: 130
82
oh yeah i have a bunch of misfuel from work too, quarter of a tank in a passat of derv, then the guy put 40 quid of petrol in it lolz. top up on the veg when it goes in.
Threads: 591
54
(22-08-2013, 06:32 PM)ally406 Wrote: These off the shelf cetane boosters probably are a waste of time. The active ingredient is 2EHN but it's usually there in a low concentration. Try some big boy cetane booster
good link that
a lot cheaper too than I used to pay.
what amount do you use per 20L of veg?
Threads: 28
3
Dosage is 0.1%, so for 20L would be 20ml? PM me your address, I'll drop a sample out in the post if you like.
Threads: 465
114
(22-08-2013, 08:51 PM)Chris_90 Wrote: (22-08-2013, 04:58 PM)cully Wrote: free misfuel / white spirit / old engine oil FTW on my old 106
it had a bosch pump
misfuel is a mixture of diesel and petrol from cars that put the wrong fuel in at filling stations
if you have a friendly garage they will give it to you for free or cheap as they have to pay to despose of it after they have removed it from customers cars
Threads: 343
15
23-08-2013, 07:17 AM
(This post was last modified: 23-08-2013, 07:19 AM by Chris_90.)
(23-08-2013, 12:23 AM)cully Wrote: (22-08-2013, 08:51 PM)Chris_90 Wrote: (22-08-2013, 04:58 PM)cully Wrote: free misfuel / white spirit / old engine oil FTW on my old 106
it had a bosch pump
oh im on a lucus all tho im running bio-diesel so no idea how long pump will last and once it dies hopefully will be haveing a 306 Bosch on.
Threads: 591
54
(22-08-2013, 10:12 PM)ally406 Wrote: Dosage is 0.1%, so for 20L would be 20ml? PM me your address, I'll drop a sample out in the post if you like.
nah its ok
once the 2.1 is going I'll get some. £14 is half what I used to pay!
