14-08-2013, 10:47 PM
		Where's the best place to get some threaded bar. Need it for tomorrow so has to be in store.
Cheers
Cheers
					best place to buy threaded bar
Cheers
		14-08-2013, 10:52 PM
		Do bnq do it? I've just checked their website and couldn't find any hardened steel.
Mind you, I didn't look hard or long... (Inb4giggidy)
		14-08-2013, 11:10 PM
		Buy a bolt and cut the head off?
Don't know if that would work for your purpose
		14-08-2013, 11:20 PM
		No, its for a stus and but conversion
		14-08-2013, 11:50 PM
(This post was last modified: 14-08-2013, 11:50 PM by zx_volcane.)
		check out your local fastners  - they'll have all sorts of threaded bar, bolts, nuts ..etc
they might sell you bits n bobs for tea/biscuit money too as they normally deal in large quanitites on a trading estate near you
		15-08-2013, 06:53 AM
		Bnq do threaded bar but only in normal sizes no fine pitch's
		15-08-2013, 08:35 AM
		15-08-2013, 08:40 AM
		Both B+Q and Homebase sell it. As do screwfix and the like.
If your looking to make wheel studs though buy actual wheel studs. IIRC the DIY store stuff is 8.8 hardness and studs should be 12.9+. I wouldn't scrimp on the stuff that holds your wheels on especially if your planning on tracking it.
		15-08-2013, 08:43 AM
		Maannn I wouldn't ever consider using off the shelf bar for a stud conversion.
Super dooper high tensile as a minimum, but if your're just using a straight bar, what's to stop it carrying on through the hub when you tighten the nut up? http://www.larkspeed.com/index.pl?p=361SS24&a=i - 99p each. Don't be such a cheapskate. Matt-Rallye Wrote:Norledge for prime minister. Poodle Wrote:I reckon Norledge has got it on the head mind. Matt-Rallye Wrote:Norledge gets my vote tbh.
		15-08-2013, 11:27 AM
		Normal threaded bar isn't even 8.8, it's 5.4, soft as shit. You need at leat 10.9 grade hardened stuff, which you generally won't get off the shelf,  shop4fastners or similar are the best place, or if you have a proper local fasteener supplies they might be able to order you some in for the next day.
		15-08-2013, 11:54 AM
		Just to sum up Sean,  both me and Stu telling you something is pikey as f*ck and a bad idea should really ring alarm bells in your head
		15-08-2013, 11:56 AM
	(15-08-2013, 11:54 AM)Dum-Dum Wrote: Just to sum up Sean, both me and Stu telling you something is pikey as f*ck and a bad idea should really ring alarm bells in your head This. Wheel bolts are 12.9 rated for a reason. I wouldnt even consider using anything i wasnt 100% sure was 12.9. just asking for trouble.
		15-08-2013, 12:02 PM
		Most are 10.9 but yeah.
As said last night, B&Q threaded bar is a BAD idea.
		15-08-2013, 03:54 PM
		I've found some 10.9 grade from a bolt n but type shop.
Hes after £9 pm. And he can cut it to size for me. Grant had a guest at 100mm and I've measured and it seems about right. What do others think?
		15-08-2013, 04:08 PM
		So your paying £9pm and you'll need 2m which is £18. Actual proper wheel studs are only about £1 each from speed shack (thatll be £16 then)
JUST BUY PROPER F*CKING STUDS YOU F*CKING INBRED MONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!! To measure the length of stud you'll need you need to go about 8 turns into the wheel and the same again into the nut. this is 10mm for each. You then need to add the thickness of the brake disc, the thickness of any spacer your gonna use and the thickness of the wheel (use the old bolt to measure) Add it all together and you'll have an accurate length. (15-08-2013, 04:08 PM)Dum-Dum Wrote: JUST BUY PROPER F*CKING STUDS YOU F*CKING INBRED MONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!! What he said (Have some Reps). Plus proper studs has a swelling after 10-15mm of thread to stop it just treading through the hub...( Matt-Rallye Wrote:Norledge for prime minister. Poodle Wrote:I reckon Norledge has got it on the head mind. Matt-Rallye Wrote:Norledge gets my vote tbh.
		15-08-2013, 04:21 PM
		This is the most retarded thing i have ever read.
		15-08-2013, 04:32 PM
		15-08-2013, 05:00 PM
		Haha! Halfords are theiving lady gardens
		15-08-2013, 05:15 PM
		15-08-2013, 05:20 PM
		Oh dear...all I can say
	![]() 138 BHP XSI
		16-08-2013, 10:30 PM
		Jesus christ Sean what the actual?
GTFO and don't come back until you've bought some proper hardened steel studs and some threadlock. Welding and fabrication projects undertaken, contact me for more information.
		You will struggle getting 10.9 or 12.9 rating long bar for this job.
Try your local nut and bolt place, use yellow pages etc. Oh and OE bolts are 10.9 as standard, although for hard driving ie track driving stc I would not use anything less than 12.9.  |
