window motor
window motor
Drivers side ph3 3 door window motor wanted either collected or posted please Smile
Bump. Desperate seeing as i cant use my drivers window lol
Ph1 the same? Im sure I have a pair of ph1 motors in the cupboard
Nah they arent. Plugs are different Sad Cheers anyway!
I used a ph2 one in my ph1, or is it between ph2 and 3 they change?
(18-08-2013, 10:18 PM)Stephen Wrote: I used a ph2 one in my ph1, or is it between ph2 and 3 they change?
Correct. Ive seen some where you can actually remove the plug from the motor and fit the one from your old motor then plug in the loom but ive also seen some that you cant so want to be sure i can plug it in lol
Fair enough.
Has to be the right number of doors too, I made that mistake once
I got one you want the runners and stuff complete? Not sure if my motor is separate or not but will send full lot
[Image: J5hxCcC.jpg]
  Wanted: drivers electric window motor/cables/liftframe cully 6 2,921 14-10-2014, 10:45 AM
Last Post: Toms306
  Wanted: Drivers side window motor Carlos vinyls 9 4,307 01-08-2013, 08:28 PM
Last Post: bigcheez2k3
  Wanted: front passenger window reg/motor mech Piggy 3 2,423 01-07-2013, 11:54 AM
Last Post: Piggy
