Shed Clearout, LOTS of Cheap Parts!
Esso BV Gear Oil (PSA OEM stuff) - £15 + P&P SOLD
GTi6 OEM Airbox inc. nearly new filter: £10 + P&P
GTi6 Resonator: £5 + P&P
GTi6 Heater Matrix Hoses: £8.00 + P&P
AC bottom hose, assumed to hold pressure but not sure: £5 + P&P
Lemforder Track-rod End, brand new unused: £12.00 + P&P
Pattern Top-mount bearings: Sold
GTi6 ECU, not unlocked: £15.00 + P&P
Lambda Sensor (I think it's Bosch but can check if required) £15.00 + P&P SOLD
2 x ICVs, sold as seen, but pretty sure they are fully functioning: £10 each + P&P 2 SOLD
Baker BM Group N lower engine mount: £20 + P&P SOLD
GTi6 OEM Mann Oil Filter: £3 + P&P SOLD
GTi6 (may fit other models) sandwich plate adapter - £8.00 + P&P
Kenwood HU good working order, worked with a sub and amp, and has an aux in socket - £15.00 + P&P
OEM CD HU - SOLD
Crystals inserts - ideal for blackmasking to avoid wrecking your only set! £8.00 + P&P for the pair and the spare lense
JL Audio Components: £25.00 + P&P SOLD
2 x mini cameras - work very well for filming driving, just ignore the hilariously inaccurate translations of the marketing guff on the packets! £7.00 each + P&P 2 SOLD
GTi6 Inlet Manifold, c/w Injectors: £20 + p&p SOLD
Ed. I want the gbox oil. Filter. And icv
Would you hold the top mount bearings till the action day at castle coombe?
Hoya mate, what's the image like on the cameras? Are they dashboard mounted?
I mounted it with Tape using one of the mounts provided in the pack. It's easier to mount to a window tbh, but I'm sure you could rig something up.
The image quality isn't that bad, particularly considering the price. It's no go pro, but it's a decent cheap solution!
I'm trying to upload a video taken on it onto youtube, I'll link you later if you're interested Smile
Frosty pm'd, Sean one coming your way soon! xx
Cheers
Top mounts sold!
(11-08-2013, 08:24 PM)Ed Doe Wrote: I mounted it with Tape using one of the mounts provided in the pack. It's easier to mount to a window tbh, but I'm sure you could rig something up.
Cheers
I am interested tbf as the other night I nearly got had in an insurance scam! Luckily enough for me my brakes are good! For that reason I am looking for a cam to put in my window but can't afford a go pro ATM.
What's the memory like? Sd card or something equivalent
Dazza I would point out that the battery isn't fantastic got what you intend to use it for. I found it used to last about an hour of constant use, so if you're planning on longer journeys these may not be ideal. But because most track slots are between 15mins to half an hour this should be ideal for that kinda thing which was my thinking. Until the missus bought me a go pro for Christmas!!!
It takes Micro SD cards, and my 8GB one used to last me the morning commute and the evening commute when I was using it (trialling it for where to locate the camera etc).
I have dibs on the Thermostat housing remember Wink
[Image: kim.png]
Pm'd You
Ed your pms....
[Image: sigi-2.png]
If you still got components next Saturday ill have them. Im assuming they are direct fit for 306?
Kingy yes they're direct fit to a 306, came out of my diablo gti6, and worked very well there!
(12-08-2013, 09:44 PM)Ed Doe Wrote: Kingy yes they're direct fit to a 306, came out of my diablo gti6, and worked very well there!
Can you put them to one side for me pweese ed?
do you still have one of the mini cameras left?
If so how much posted?
Titch
Bumpbump!
Titch, I've still got both cameras, I'll drop you a pm now Smile
Kingy you have a pm....!
Cheers
Ed
ewar, you useless bastard, you never put a video up!! fukkit, i'll have a camera too tho.
but if it's shite, i'm raping you, and your cat.
Sorry buddy, my sodding useless computer kept changingrthe aspect ratio every time I tried to upload it. No point if you're trying to see what quality it can do if it changes the quality when I edit it to upload a clip!
It's not bad for what it is man, you should get on fine with it!
Morning all,
Updated with what's sold Smile
Things gotta go guys, try me!! Smile
Pm'ed
edwardoe, whatsapp me or something
Interested in the jl components mate how much delivered? PM me Wink.
Hi mate, sorry the components are provisionally sold, and Danny2009 has 2nd dibs if that falls through. I'll put you down for 3rd dibs, but can't promise they'll be about!
No worries they're cheap cant say I'm surprised.
Heater matrix hoses £2
You sure they'll fit your engine buddy? £3 and they're yours Smile x
£2 and ill take them Smile
Ed you gayer! You promised me the thermostat housing.... update please Big Grin
[Image: kim.png]
£2 take it or leave it Smile
  Last parts clearout John1.4 0 1,211 02-02-2020, 08:46 AM
Last Post: John1.4
  Parts Going Cheap - Breaking '99 HDi wainwrightj 15 7,187 04-06-2019, 07:29 PM
Last Post: Charlie0
  306 Parts Clearout, suspension bits bobs + others tigerstyle 4 2,565 19-08-2017, 08:22 PM
Last Post: Frosty
