25-10-2012, 02:00 PM
Hi there.
I'm 306brasil.com.br moderator, and think fair debut here collaborating with somehow (i hope)
What you need:
- Torx (T15 or T20)
- 10mm wrench
- Philips screwdriver
Remove the front wheels helps the service
First, remove these 3 screw with the Torx in both sides
After remove, this part is out
This will give access to the upper screws bumpers
After this, remove these 3 screws in the sump guard with 10mm wrench
Finishing this, you have the lower part job finished.
Now starts the boring part.... The upper nuts.
2 nuts in the left side (Passenger side in the UK cars) - 10mm wrench
And 2 more in the right side (Driver side in the UK cars) - 10mm wrench
Ignore the black nuts (whitout prejudice :p), what matter are the silver nuts.
Finishing this, the bumper is out!
The "X" tags are fit points and the "circle" tags are fixation points with the nuts/screws
In the car
And in the bumper
The "square" points are the fog lights fixation.
Regards, Ambrosio
(sorry for my bad english)
What you need:
- Torx (T15 or T20)
- 10mm wrench
In the car
And in the bumper
Regards, Ambrosio
