GTI-6 cone fitting
GTI-6 cone fitting
Need to buy a new cone for my car, can someone tell me what I need to get the cone to clear the top radiator hose?
ive read that the cone needs to be 76mm inner diameter, but any idea on what type of pipe would be best? like a straight pipe or 90 degree bend down or?
thanks
90 degree bend 76mm
do I need a connector to join the cone to the hose?
Ideally you could do with one if you are sticking with the beginning of the OEM pipework with the icv feed thing in, though if you are sticking a breather hose on that, you can just go throttle body->silicone->cone
You want the longest straightest pipe you can manage. Ideally you could f*ck the ABS off and have the filter behind the NS headlight
  cone filter fitment willJspears 8 3,315 29-04-2014, 10:04 PM
Last Post: 7057sam
