20-07-2013, 07:25 PM
There's been a fair bit of interest in my 205 GTi spares so I thought I may as well list the majority.
Black ph2 N/S rear arch trim - £10
Black ph2 N/S door trim with red strip - £10
Red GTi carpet and carpeted lower dash console. Needs a clean but otherwise in good condition - £20
8v inlet manifold with fuel rail - £5
8v inlet manifold with throttle body, 1.6 injectors and fuel rail - £10
205 opening rear window glass - £5 pair
205 GTi rear anti roll bar - £10
8v alloy engine mounts £5 ea
205 Jack - £5
Front washer bottles - £5
Ph2 black gear gaitor surround. Gaitor itself is in poor order - £2
Electric window switches within panels pairs of left right - £5 the pair
Seatbelt slider rails next to sill - £3 pair
Ph2 black heater control panel cover with clear symbols - £5
Ph2 black boot hinge plastic covers for roof lining - £2 pair
Ph1/1.5 red rear valance ‘faux fog’ cover - £5
Ph2 black internal mirror covers. Drivers side has screw holes. Minimal clips - £2 pr
Ph2 black triangle trim above coin tray. 1 snapped clip - £2
Map light - £2
Ph2 black interior door handle opener. Pass side - £2
Ph1/1.5 grey interior door handle opener. Drivers and pass side - £2 ea
Ph1.5 grey large door grab handle - £2
Ph2 black large door grab handle - £2
Ph2 black clock surround with all clip - £4
Ph2 black dash vents Left and Right. Drivers side has hold for immobiliser - £5 pair
Ph2 black central dash vents - £5
Ph2 black cufflink tray for behind gear gaitor. All clips in tact - £5
Throttle pedal x 2 - £2 ea
Rear wiper arm - £2
White bonnet hinges - £5 pair
Boot striker plates - £1 ea
Cig lighter - £1
Handbrake. No sleeve on it - £4
Ph2 black steering wheel surround. Top and bottom - £5 for both
Ph2 black lower right large dash panel - £5
Ph1.5 grey footwell kick plate drivers side - £2
Ph2 black footwell kick plate both sides - £4 pair
Ph1.5 grey handbrake surround - £4
Ph2 black handbrake surround. 2 broken fixings – FOC
Ph2 black sunvisors - £5 pair
Ph1.5 grey door cards with red carpet - £10 pair
Genuine Peugeot 205 5 door roof rack - £20
Diesel 205 twin fans in cowling - £10
ph1 expansion tank - £10
Ph2 expansion tank - £10
8v cam cover - £5
Ph 2 fuel sender - £5
Spare wheel hook bolt - £5
Collection available from FCS or I can post
205 Jack - £5
Map light - £2
Rear wiper arm - £2
Cig lighter - £1
8v cam cover - £5
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
BMW Z4 3.0
![[Image: AEFA784E-0367-40E7-B849-AF7ECAE53CB1-147...a20009.jpg]](http://img.photobucket.com/albums/v318/blueovalspanker/AEFA784E-0367-40E7-B849-AF7ECAE53CB1-14730-00000F55D7F3BAE2_zps03a20009.jpg)
![[Image: 394B0F4C-BC50-4936-8358-4102526DA106-147...f08e4e.jpg]](http://img.photobucket.com/albums/v318/blueovalspanker/394B0F4C-BC50-4936-8358-4102526DA106-14730-00000F55DD9BE4F1_zps35f08e4e.jpg)
![[Image: signiture.jpg]](https://lh4.googleusercontent.com/-7ORHe1luJy0/UIW7RcRdrGI/AAAAAAAABjE/n7i9b1goCYM/s500/signiture.jpg)
Ha. That's always an option
