Threads: 22
Car Model/Spec: Bmw e36 328i coupe
25-07-2013, 07:04 PM
(This post was last modified: 25-07-2013, 08:15 PM by thethorne.)
Xud it's been rebuilt
#new big ends
#new gaskets
# cambelt kit
#water pump
# new breathers
# clutch
# hdi box
# hdi rods
# hdi sump
# head refurb
# new td05
# xantia inlet manifold ported n polished de egr'd
# custom turbo exhaust manifold
# recon injectors
# all new sensors
#bosch pump
# new injection pipes
# new oil cooler
# starter
# alternator
# powersteering pump
# full head rebuild and skim
From what I can tell and been told its been fully rebuilt and no expense spared!!!
Basically wire up stop solenoid and put fuel lines on and it'll go. Everything is included can include shafts for a few a extra £££
The engine has been painted brown and black. It has crackle effect rocker box and is very clean ( except oil I spilt on gearbox which ill clean off)
I was given the job to fit this engine to a customers Berlingo but his circumstances changed and couldn't afford work so was given engine as payment.
Looking for any cash offer around £ 225 for the lot.
07780220785
Will add pictures later.
25-07-2013, 07:06 PM
(This post was last modified: 25-07-2013, 07:08 PM by Piggy.)
has it had arp head studs?
what head gasket used?
standard pump??
what clutch??
what gearbox?
Threads: 22
25-07-2013, 07:12 PM
(This post was last modified: 25-07-2013, 07:15 PM by thethorne.)
Pretty sure it's got hid box?
Was told its got hid rods cannot confirm
Studs no idea same as gasket.
It has hdi alloy sump?
New belt kit and water pump.
The td05 is brand new also.
You can see its had new gaskets every where.
trying to get more details on it.
It's priced for me to break even.
Hdi*** bloody iPhone lol
Threads: 100
I will have it, if you can prove all that stuff that's been done.
shame about the studs.
what clutch was put in? and if you can find out about the bosch pump?!
Threads: 448
51
Mark, Callum probably did all the work himself.
So will be his word and a few receipts.
Threads: 22
Come av a look at it ill put pics up in a min
Threads: 127
33
Car Model/Spec: ZX Volcane TD
bargain, this should be snapped up
Threads: 100
Ok I will take it, just need to sort out collecting it.
Threads: 22
Just been told this was built with the aim of 200bhp. Unsure what this mean in terms of head bolts or gaskets or anything like that....??? That's everything I no.
Threads: 448
51
I think I saw this engine? Looks pretty good standard!
Threads: 22
Where did u see it?? It came out a 306 estate that some how in round about way got swapped for my 6( not by me) then some how I ended up getting asked to fit this engine. Then the owner of this engine ran out of funds and I got given the engine to cover my costs n labour. Long story short some one buy it
Threads: 100
I am buying it. Just need to sort out delivery.
Threads: 448
51
f*ck knows! I just remember the colour scheme lol
Threads: 22
Think it briefly appeared on ebay still fitted in a car which my mate owns now.
Threads: 90
Thats really cheap tbh, someone should be snapping this up!
Threads: 22
If some one wants to offer more go for it lol. I just want my money for wasted time I run and business and have wasted labour n oils I want covered by the sale of this.
Threads: 203
Car Model/Spec: Peugeot 306
this was built by liam rudge and fitted into a 306 estate to start off with but had running problems so he sold it
Threads: 100
What kind of running problems?
ah yeah the estate came up on ebay or sumit...was linked to on here.
you would have issues getting the td05 to spool
Threads: 22
26-07-2013, 07:49 AM
(This post was last modified: 26-07-2013, 07:52 AM by thethorne.)
Running issue was thought to of been pump. Until a straight diesel was fitted and it ran the same turned out to be a crushed fuel line coming from the tank.
None of which I been paid for...
Teddy is only aware of this issue as I stated it on Facebook a few days ago.
Threads: 203
pretty sure he ran a bosch pump on the lucas pins on the fuel hosing to start off with it looked a tidy job but i know he struggled to get it to fire when he first finshed it because he had ran it with low oil
