Threads: 164
25
Car Model/Spec: Gti6
Been out and about today and had an issue develop on the 6
Was fine for most of the day parked up and when i set off noticed Whenever i accelerate the car pulls to the right and when i lift off pulls left
Could it be a tracking problem or something more serious? I know the top engine mounts not great...
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Sounds tracking.
Get it done professionally for an accurate result
Phaes 1 GTI 6 - Onyx Black
Threads: 206
3
Car Model/Spec: 3dr dt-s
wishbones moving= p bush gone to meet its maker ??
check/replace and only then get the tracking done
Threads: 169
91
I would likewise go with P-bushes. Had similar symptoms when mine separated from the housing. Tracking would cause problems in one direction, not both.
Threads: 164
25
Seems to only have the issue when turning right or going straight, left is fine
Estimated cost of p bushes and best place to buy?
Threads: 6
Car Model/Spec: Astor 6'
(15-07-2013, 07:24 PM)rocker8742 Wrote: Seems to only have the issue when turning right or going straight, left is fine
I'm having exact same issues at the mo, p-bushes are cheap (about£12) but you need a press to get them in. Check the bolts that hold the wishbone on by the p-bush as well as my bolt had sheared off completely creating even more wobble under load and braking.
Threads: 164
25
Had them swapped over yesterday and apparently the captive nut had sheared off aswell
