Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
As above looking for some good 266 calipers must be good condition with free bleed nipples, be nice if they come with good discs and pads??
Also need a 4 port 22mm master cylinder or something like that
What you got? Cheaper the better
Pick up from pugfest or fcs would be best to save on postage
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
I got some 266 front brakes. They came off a hdi and have good discs and pads. Just surface rust on the discs which will clean up with use. I will upload a pic later if your interested?
Threads: 343
15
Yer defo interested mate free bleed nipples? And you comeing to pugfest/fcs? How cheap are they
Threads: 127
33
Car Model/Spec: ZX Volcane TD
got a 22mm ms, but its only 2 port
Threads: 343
15
(10-07-2013, 06:26 PM)zx_volcane Wrote: got a 22mm ms, but its only 2 port
Won't be any good for me thanks anyway
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Good man, they stop uber well in a nad lol
You do know you need to grind a bit of your carrier away to make them fit yes?
Threads: 110
20
(10-07-2013, 05:06 PM)Chris_90 Wrote: Yer defo interested mate free bleed nipples? And you comeing to pugfest/fcs? How cheap are they
I will check the bleed nipple. I will be going FCS and £20 no lower. Will load a pic up in a sec
Threads: 343
15
(10-07-2013, 08:07 PM)Frosty Wrote: (10-07-2013, 05:06 PM)Chris_90 Wrote: Yer defo interested mate free bleed nipples? And you comeing to pugfest/fcs? How cheap are they
Ok mate will have them off you at fcs if bleed nipples are free
Threads: 110
20
I will check tomorrow and let you know
Threads: 343
15
(10-07-2013, 09:57 PM)Frosty Wrote: I will check tomorrow and let you know
Ok mate thanks
Threads: 15
Got the full brake setup off my hdi mate?
Threads: 343
15
(11-07-2013, 11:31 AM)tbaxter08700 Wrote: Got the full brake setup off my hdi mate?
Has it got 4 port master cylinder?
Threads: 591
54
you wont find a 4port from a 306 bud.
Threads: 343
15
(11-07-2013, 05:39 PM)Piggy Wrote: you wont find a 4port from a 306 bud.
Ohhh you no we're I can get one from? Was tempted with 23mm but just don't want a solid pedal rather have a bit of feel to it
Threads: 591
54
11-07-2013, 05:54 PM
(This post was last modified: 11-07-2013, 05:55 PM by Piggy.)
duno much on the 106 scene....what about a 106 gti M/C?! is that 22mm?
I love my 23mm. awesome. with the 5.1 fluid and braided lines feels like you are actually in control.
Threads: 110
20
The bleed nipples are all free mate. So you defo have them?
Threads: 343
15
(11-07-2013, 05:54 PM)Piggy Wrote: duno much on the 106 scene....what about a 106 gti M/C?! is that 22mm?
Might go for 23mm are 306 gti6 4 port?
(11-07-2013, 08:28 PM)Frosty Wrote: The bleed nipples are all free mate. So you defo have them?
Yer will have them mate pick up from fcs?
Threads: 110
20
yeah thats cool. Are you camping with oc?
also gti6 mc are 2 port. no standard mc is 4 port as far as im aware
Threads: 343
15
(11-07-2013, 08:47 PM)Frosty Wrote: yeah thats cool. Are you camping with oc?
I'm not Will be on 106 stand tho comeing down on the Saturday morning will inbox you my number when it's closer so I can meet you there some were to get them off you.
And ok there must some 4 port ones got that's what the 106 guys use have to look in to it abit more
Threads: 110
20
Threads: 343
15
Wanting these asap if any one local got a set up that I can collect would be best????
Threads: 110
20
You should of has the 1s off me. Though I have still got them
Threads: 343
15
(04-08-2013, 07:32 PM)Frosty Wrote: You should of has the 1s off me. Though I have still got them
I've messaged you?? Before I bumped this up you not got it??
Threads: 110
20
(04-08-2013, 08:25 PM)Chris_90 Wrote: (04-08-2013, 07:32 PM)Frosty Wrote: You should of has the 1s off me. Though I have still got them
Replied
Threads: 343
15
Threads: 591
54
have you considered getting a 106 gti MC which is two port and just plumb it with additional pipe work?
Threads: 581
195
Chris ive got a good set of 266 callipers with discs and pads sitting in the shed that i will never use. Yours for £30 plus postage.
Threads: 30
4
Car Model/Spec: Bianca 6 + 205 1.9 Gti
Given 1 thank(s) in 1 post(s)
Cant really compete with these but got some 266 calipers on there own in hammerite yellow id let go for 25 posted with fees covered?
Threads: 343
15
(05-08-2013, 09:52 AM)Piggy Wrote: have you considered getting a 106 gti MC which is two port and just plumb it with additional pipe work?
I have yes but tbh rather have a 22/23mm 4port to save the hassle, all though I have thought about a 23mm 2port and get some exact braided lines up with brake bias valve for rears so they don't lock up, bit not sure what that would cost
(05-08-2013, 11:38 AM)Niall Wrote: Chris ive got a good set of 266 callipers with discs and pads sitting in the shed that i will never use. Yours for £30 plus postage.
Depending on price on postage may be interested? And if the bleed nipples free?
(05-08-2013, 03:54 PM)Jaymes306 Wrote: Cant really compete with these but got some 266 calipers on there own in hammerite yellow id let go for 25 posted with fees covered?
I will keep that in mind thanks
Threads: 581
195
Postage will probably be about £10-15. Will weigh it all tomorrow for you  Also, the nipples were free last time they were used but they have sat for a few years. Cant see them seizing up though sitting in a dry shed!
