Threads: 127
1
Car Model/Spec: 306 ph1 xrdt , Golf GTTDi 130
hi all,
can anyone tell me whether a set of 16" nimrods off a 206 gti will fit straight onto the hubs on a 306 hdi or will they need spigot rings/spacers etc?
thanks
Threads: 20
6
206 ones need spacers yes
If you get them from a 406? Iirc you don't need spacers
Threads: 20
6
10mm or bigger iirc
You will also need extended wheel bolts
Threads: 208
60
Given 5 thank(s) in 5 post(s)
You can get away with 5mm on the rear and nothing on the front. But it looks shit. Especialy id you have a lowered car.
10mm all round is ok but personaly id go 15mm on the rear and 10mm on the front
Threads: 541
124
The wheels are the same center bore yes
Its 13mm spacers you want all round to make it the same offset as the 306 as the wheels are ET31 and the 306 uses ET18. 31-18=13mm
Is that £85 posted with bolts cos if so thats VERY good. I was paying £37 a pair for spacers alone.
Make sure you get the right sort of bolts as pug wheels take flat seat bolts not the taper seat bolts that you often get given. If you use the taper seat bolts youll f*ck your wheels and they will work loose over time as the bolt damages the wheel.
