shocks
shocks
foudn some 40mm lowering springs of a 1.9diesel 306 wiht the shocks, will they fit straight on to a hdi?
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
Yes they will, however you may want to just quickly check the engine weights, as I think the HDI is heavier than the 1.9XUD. If they were meant for a lighter engine they will obviously lower a car with a heavier engine by a greater amount Smile
(04-07-2013, 11:36 AM)Ed Doe Wrote: Yes they will, however you may want to just quickly check the engine weights, as I think the HDI is heavier than the 1.9XUD. If they were meant for a lighter engine they will obviously lower a car with a heavier engine by a greater amount Smile
there 40mm lowering springs with shocks, so would mean it lowering it by say 50mm? Big Grin
yeah or maybe closer to 60mm
(04-07-2013, 12:54 PM)Piggy Wrote: yeah or maybe closer to 60mm
perfect thanks Smile
