Brake Hoses
Brake Hoses
Quick question. Are 106 and 306 hoses the same? If not, where can i get 306 hoses for Hispec callipers except Swampy?
Cheers Heart
No the length is different!!
Fittings are the same
M10x1 female at body end
10x1 20degree banjo the other end
Looking at the thread gti6 you don't want them 600mm long
Give me half an hour and ill dig the specs out
Thanks Swampy
Standard gti6 length is 532mm
That's total hose length from the top of the female union to the base of the base of the hex that screws up against the caliper.
I Would ask them to make the hose 550 cut length plus the length of the unions, that's the dimensions I work too when I supply them for hi spec and BREMBO.
Of course that's if it's going on standard disks, if your fitting a big disk kit aswell then you need to make them slightly longer agsin
Cheers for the info Smile
  Cheaper Braided Brake Hoses Toms306 11 5,390 05-08-2016, 10:22 AM
Last Post: PocketFighter
  Where to get retaining clips for brake hoses? Spoonaltap 5 3,095 30-07-2016, 05:36 PM
Last Post: Spoonaltap
  rear brake hoses Iaitoo 2 2,278 05-05-2016, 12:01 PM
Last Post: Iaitoo
