Threads: 448
51
Have you used the 1.8 sensors on the mani? If so have you done a ecu reset?
Threads: 28
Yeah its got the 1.8 sensors on. Haven't tried ecu reset yet but I'm concerned about the squeal. Seems to me like air could be getting in somewhere?
Prat
There is a air leak somewhere after the throttle body. More than likey where it bolts to the head. New gasket is essential! Try spraying WD40 around the joins and see if it revs. If it does, theres your leak.
(02-07-2013, 07:50 PM)Matt Wrote: Yep air leak, the bottom of the manifold can be an issue, seem to remember someone having a problem with it getting caught up on something and not sealing correctly. Do as Niall says. If that sorts your squeal then sorted. ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
That was me
Threads: 448
51
Yeah that pipe normally is an issue, you just need to adjust slightly. Can't see what you issue is. Made sure all the bolts are nice and tight?
Take the manifold off and make sure there is no old gasket stuck to it or the block. I used a single sided blade to clean mine up as it can be a PITA to do.
btw text me. I want to know if your coming to FCS with us!!
Threads: 3
Car Model/Spec: Passion XU7JP4
Do you fit GTi inlet in a XU7? If yes, probably the injection send "poor" mixture.
Threads: 28
Sure did yeah. And it had the xu7 injectors and pressure fitted along with all the 1.8 sensors so all was okay.
