Water meth pump
Bought from kernow_joe
Never got round to fitting it, which is a crying shame as would have loved to have got it running.
Unfortunately I'm needing funds for my engine rebuild so might as well let it go.
£60 posted or collection from near Birmingham welcome
[Image: 2011-06-17%252018.31.55.jpg]
fyi its exactly the same make of pump devils own use and why you don't run more than 50/50 meth to water (ie flammable liquid)
that pump is the same as what a couple companies use for there w/m pumps :/ plus w/m isnt explosive as such your not ment to run 100% meth 50/50 mix Wink
oops beaten to it Big Grin
what flow rate is it?
spose 50/50 be ok
Thread cleaned
I forgot I sold this was actually looking for it over the weekend Smile
shame I'm skint otherwise would have thought of buying this back.
[Image: signiture.jpg]
^bump
Weekend bump
Bump, just rediscovered this about the garage
Back to the top!
Happy to help put together a kit / fit if anyones needs a hand -its a piece of cake to sort out
Bump on this
Can put this together with a nozzle, pressure switch and wiring harness,
So pretty much good to go, you will just need to tap into your washer bottle and pick up some pvc hose and one way valve - which again I'm happy to help sort out.
How much for the pump, pressure switch and nozzle posted thanks Chris.
Bump!
Have pump, nozzle, nozzle holder, pressure switch and relay - all you need is some pipe and a one way valve.
PM incoming, you literally might as well just PM me parts in future, seems like I'm buying at least an item a month! Tongue
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
  New XUD water pump and used 306 front wiper motor powerandtorque 0 1,786 25-10-2015, 09:24 PM
Last Post: powerandtorque
  For Sale: Engine mounts, water pump, FMIC ginge191 10 6,902 18-04-2013, 05:18 PM
Last Post: ginge191
  devils own meth injection kit ash23 12 5,588 18-02-2013, 10:21 PM
Last Post: ash23
