Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
51mm I think I measured mine at.
Threads: 198
135
Just get a 2" reducer for it, will tighten down with a clamp anyway
Threads: 202
58
The standard T2 intake pipe will just fit with a little persuasion.
Threads: 90
54
Run the BIGGEST pipe you physically can to it if your not running it open filter, the inlet pipe will restrict the turbo more than anything else on the entire induction / boost system, 30cm of pipe of the same size as the turbo inlet will be hugely restrictive, granted theres is shag all room down the back of an xud to run anything much bigger, hence most get left open, but its well worth trying!
