09-06-2013, 09:54 PM
just a quick question was looking to buy a 1.9 straight diesel 306 the timing is slipped on it and i have a 406 1.9 turbo diesel , and wanted to swap engines but will the wiring loom s be the same
engine/wiring loom help
10-06-2013, 11:43 AM
Remember the 406 has a semi ecu controlled pump for timing advance etc so you might be better off changing it for a 306 dt pump before it goes in rather than getting it to work with the ecu
10-06-2013, 12:07 PM
10-06-2013, 05:05 PM
11-06-2013, 09:22 AM
(10-06-2013, 05:05 PM)Mal Wrote:(10-06-2013, 12:07 PM)bigcheez2k3 Wrote: Not all of them, only the later ones. Pump in my old car was off a 406. Can you explain more about the ecu controlled pump? Is it easily identifyable with extra wiring to it etc Only asking as the replacement engine and pump in my zx is from a '97 306 td, it had an extra blue plug on the pump which is not used with the zx loom. Car runs great but very occasionally cuts out when on boost at fairly high revs, always restarts without issue but was always curious about the extra wiring to the pump? Sorry for the thread hijack. David
11-06-2013, 09:52 AM
If it's from a 306, and that pump was on the car from the factory, it won't be the ECU type.
11-06-2013, 11:38 AM
11-06-2013, 02:56 PM
(11-06-2013, 09:22 AM)Zippy121 Wrote: Can you explain more about the ecu controlled pump? If the pump is from a 306 it'll be the non ECU type. Easy to tell apart, here's one I made for my 406, note the piece that sits on top of the throttle arm (cannot remember what it's called it has a plug) a 306 pump won't have it
11-06-2013, 05:25 PM
I see, radically different and i guess a Bosch pump?
the part youve described looks like a throttle position sensor to me which makes sense with it having an ecu control. My pump does although have a blue plug (unused on my install) which operated a small micro switch (again unused) and is a Lucas pump. Thanks again, very interesting. David
11-06-2013, 05:46 PM
(11-06-2013, 05:25 PM)Zippy121 Wrote: I see, radically different and i guess a Bosch pump? Potentiometer! That's the part I read on here somewhere that the internals are slightly different in regards the diesel channels for the timing piston and that converting one to the other generally won't work ie slapping a potentiometer on a mech pump and expecting it to work! I'm in 2 minds whether to convert my 406 to full mech or not. If I get a pump cheap I will but the system works well at the mo and I have lots of spare ECUs if one gives up the ghost The ECU pump will work without the ECU but the car will be as flat as a witches tit to drive, clatter into oblivion and coal like a train due to going into fully advanced timing. I've tried it....!
12-06-2013, 04:51 AM
I take it that I non ecu pump is more tuneable then and is this why you want to bin the ecu?
I'm still finding my feet with diesel engines as the Volcane was bought as a second car for work duties. That was five and a half years ago! Had to do an engine swap due to an incident with a large expanse of water in Wales, don't ask.. So I just have to sort this niggle with the odd cutting out problem then I may start to tweak things :-)
12-06-2013, 02:40 PM
The 306 doesn't have the facilities for the ECU pump, there is no wiring hence why everyone is warned off buying one instead of just removing the ECU stuff.
xud wiring loom (what fits) | jpderv | 4 | 1,986 |
05-02-2013, 04:00 PM Last Post: jpderv |
Engine loom | cwspellowe | 29 | 4,427 |
10-05-2012, 10:20 PM Last Post: darrenjlobb |
