Morette Crystal lamps
Wanted: Morette Crystal lamps
As title, im after a set of crystal lamps for my morettes, both inner and outers if possible, just outers would do though.
also a set of the inner lamp trumpets if anyone has any?
its all ebay stuff as far as i know!
http://www.ebay.co.uk/itm/Crystal-5-75-5...5af0f69f2b
5.75 inces is about 146mm so these could go in the outers...
http://www.ebay.co.uk/itm/Cold-Air-Feed-...27c9b620a1
http://www.ebay.co.uk/sch/i.html?_odkw=1...t&_sacat=0
however the outers are the ones you want to keep. I dont know what the inner lamp size is but im sure you can find the trumpets for that size on ebay.
and if you want crystal inner lamps then take a deep breath...
http://www.ebay.co.uk/itm/4-2-Inner-Head...0883324632
but from that we know they are 4.75" which is pretty much exactly 120mm so these should fit the insides almost perfectly!
http://www.ebay.co.uk/itm/Cold-Air-Feed-...2a20f16679
http://www.ebay.co.uk/itm/Cold-Air-Feed-...2a20f162bf
I have a set of crystal outers i am after some cibie original outers to replace them with so i will be getting rid of them once i can remove the bloody rusted nuts from the casing
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(06-05-2013, 11:06 PM)HDIkyle Wrote: I have a set of crystal outers i am after some cibie original outers to replace them with so i will be getting rid of them once i can remove the bloody rusted nuts from the casing
Il be willing to do a direct swap for my cibies if you want mate?
after seeing the ebay prices id rather do it this way lmao
  Wanted: Morette headlights Sian 9 4,520 18-08-2013, 09:54 AM
Last Post: Sian
  Wanted: Morrette inner lamps HDIkyle 7 4,200 23-06-2013, 09:17 PM
Last Post: HDIkyle
  Wanted: Morette inner lamps ash240970 4 2,927 12-01-2013, 05:54 PM
Last Post: ash240970
