Threads: 23
1
Car Model/Spec: 306 D-turbo
Hi all, I'm fitting new cam soon and no idea how they should be timed in in relation to tdc! Anyone got a basic guide for me to follow? Much appreciated in advance
Silver Five Door D-Tuurbo'! More Doors More Whores y0!
Threads: 91
83
Stock or re-profiled?
If it's stock, you simply attach the pulley and put the lock pin in and away you go. They're keyed so you can't get it wrong
Threads: 23
1
Threads: 91
83
My only advice is - good luck.
They're a complete bastard - you are aware you're going to have to reshim the whole lot?
Do you have a vernier pulley?
You'll probably find if you fit it without any sort of setup, it'll sound like a 1970s Ford Fiesta with the amount of valve noise, make less power because the stock cam pulley sets it to nowhere near correct timing and just be a bastard... Unless you've got a SIGNIFICANTLY bigger turbo and you've already ported the SHIT out the cylinder head, I wouldn't even attempt fitting it, it's more hassle than it's worth.
Threads: 23
1
01-05-2013, 09:42 AM
(This post was last modified: 01-05-2013, 09:50 AM by RhysBoost.)
Would you recommend a pulley?
I've got td04 and getting it ported and polished, they are getting ground in etc and fitted by the person who's doing the head work; all I need to do is time them up? Or is it a case if pay someone to time it up?
Threads: 91
83
You'll need a pulley, completely ignore the valve clearance specifications, they're wrong, set it to XUD standard... You'll also need to get a vernier pulley for it otherwise it ends up running something like 6-8* retarded... Then youve got to find a method of timing the whole engine as the lock points aren't there anymore...
Threads: 23
1
I won't fit them until I've got the pulley then  cheers man, may pay someone to time it up eventually?
Threads: 91
83
You can pay someone all you want, but simple as - no one knows the exact specs for that cam, I know people who've tried it and been involved with attempting to make one work at least as well as stock and I've only ever seen mixed results, I can't say I've seen ANY power improvements from the cam alone, I've definitely seen poorly set up cams cause significant issues however.
If it were me, I'd see if you can get your money back.
220hp+ has been seen on a stock cam - I saw 175HP+ and over 300lb.ft with a stock cam and stock head at 21-22lbs of boost... They're really not a restriction. Porting out the head will probably net you greater gains than the fitment of the cam.
Threads: 23
1
I got them stupidly cheap so I may aswell give it a try?
Threads: 55
3
01-05-2013, 06:17 PM
(This post was last modified: 01-05-2013, 06:18 PM by Dicky.)
If i was you, I'd listen to Ruan rather than giving it a try..
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Threads: 91
83
It'll cost you WAY more money than the cam ever was to set it up properly.
I KNOW the gains these give and as stated, they are NOT worth the hassle and the effort unless you know a thing or two about valvetrain, you're more than likely to cock it up, make less power and damage the engine... Not to mention the amount of money you'll have spent getting the valve clearances reshimmed.
I just know these cams are a bloody nightmare because the design was essentially copied... But EXTREMELY poorly - hence why all the setup data is wrong.
Threads: 23
1
Okay cheers guys may just keep them in the cupboard  finish everything then If I happen to come across a Einstein of cams and timing then slap them in!
Threads: 0
45
Why are you changing the cam?
Threads: 124
26
Car Model/Spec: Megane DCiR
I was looking into this but as ruan says more hassle than its worth invest that money in something else pal
Threads: 23
1
I've already got them had the money for a while, as I say I got them cheap enough to just put in the cupboard! That will be what's done whilst I do other bits
Threads: 91
12
Car Model/Spec: 306 D Turbo
You keep saying them, how many do you think you need!! Lol
Threads: 55
3
(02-05-2013, 02:13 PM)londondan86 Wrote: You keep saying them, how many do you think you need!! Lol for the quad cam XUD
Threads: 124
26
I was thinking exactly the same :S
Threads: 23
1
It just doesn't sound right haha! Hopefully get my td04 and hdi rods in soon
