bosch pump
wanted 11mm pump with ground lda and gov mod near essex so i can pick up this tuesday
Bump or 9mm with mods
I have a 9mm with solid governor if that's any good? I'm after £60 collected.
i got a 9mm bosch gov mod & ground lda pin but the vains need freeing up,been told its an easy fix but i aint that clued up on these pumps,if you pick it up you can have it for £40
Where abouts are you?
willenhall west midlands.
Whats happened now? No luck with them pumps do you!
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  Wanted: XUD Bosch Fuel Pump xstian 0 2,885 02-06-2020, 08:08 AM
Last Post: xstian
  Wanted: Bosch pump nominous 0 2,262 17-01-2018, 12:19 PM
Last Post: nominous
  Wanted: Modified bosch pump Chris_90 2 3,106 27-02-2017, 08:24 AM
Last Post: Chris_90
