Threads: 169
91
Anyone who's done this, how did you get the coolant hose on the rear of the engine not to make contact with the manifold?
Cheers
Threads: 581
195
Or just use the modified gti hoses i gave you when i broke my 1.8. Job done!
Threads: 581
195
Errr you do because they are moulded together in several positions!
Threads: 2
you have to buy the hose specific to the 6, it is completly different, instead of being u shaped its straight and comes complete with the metal part going across the back of the engine, but then you have to change the thermostat housing as well, as the hose has an extra sprout on it which connects to the extra sprout on the thermostat
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
Cable-Ties FTW.
Heater hose was also wrapped in heat-protective shizzle for less bum-twitching when the temperature needle started to rise...
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
