engine temp
engine temp
I was on my way home today and stuck in traffic the car temp went up to 90 degrees then my stop light came on is this normal? As soon as i got moving again temp went straight back down to normal
Did the fans come on around 90?
Nope started moving just after the light came on which was dead on 90
Not normal fans should be on low speed before 90 then just before high speed is supposed to kick in i think! Mines goes upto 90 bu the fans come on before and it drops again :/
Typical XUD. Check the fan relays behind the front grill, known for corroding
S2 HDi >click<
154bhp
280lbs/ft
is your coolant full?
Yea coolant is all full.
and Il check the fan relay tomorrow
cheers guys
  What temp. should my engine be running at? D Turbo Lyle 14 7,749 24-07-2013, 11:34 PM
Last Post: juz22
