Threads: 26
when im driving i can feel the wheels skip or grab maybe how to explain it?
i know theres play in passenger side front wheel will this be it and whats most likely cause bottom arm?
Threads: 465
114
Car Model/Spec: Vauxhall
crap tyres on a wet road?!
Threads: 26
its drive shaft fooked just had it checked
Threads: 448
51
I was gunna say, mine did this, steering wheel pulls out of your hand, car feels like its trying to kill you
Threads: 26
yer its inner cv and bairings shagged it doesnt pull wheel a lot but you feel it snatch one off the front wheels
Im getting this at certain times....same issue...inner shaft joint...
Threads: 138
72
Car Model/Spec: Mincebus
Did it clonk at all? mines feels skittish as fook driving. I don't remember if it was like that last year or not, but had generally put it down to the camber of the roads I drive... Easy way to check this?
Astor 'X' 4 GTi6-
6 - SOLD!
![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png)
no clonking for me...usually the outer ones clonk more than inners.
try twisting the shaft while wheels in the ground...feel for play and then work out which joint its in
