1.8 diesel electics
Got a 1.8 non turbo 205 run fine started ok however a lot of the wiring the the enginebay has been cut and taped up on the alarm, dead wires not connected and now since I gave everything a spray of wd the ignition is just dead. Relay clicks but fuel gauge and lights just go out. I am sure this is earth related chassis earth mainly? Anyone comfirm?
Would I be ok also to just remove the alarm and any other wiring involved with it. I am going to be fitting a Bosch pump so if it does have an immobiliser into the alarm it will be bypassed anyway.
Also the rear fog light is very tempremental I cannot get it to work yet she says it did work when she was following. And the seaside tail light is also the same. But the wires have been snap Locked on so should be a simple fix
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Is it an aftermarket alarm or an OEM one?
Does sound like an earth issue mind.
Looks oem I believe
Blaze 1.6 Dead
