Threads: 198
135
04-04-2013, 09:54 PM
(This post was last modified: 04-04-2013, 10:06 PM by cwspellowe.)
I've just realised i've tried timed runs with a boot full of bull bars, tool box, car parts, a roof rack with a spare wheel, medi box, shovel, f*cking all sorts. Must be pulling a good 1400+kg including the driver.
Yeah i thought those times were a little slower than I hoped
Book figures appear to be unladen weight of around 1200kg, 0-60 14.1 seconds and top speed of 112mph. Yeah I think I blitzed that.
Makes 24psi by 2.5krpm, happy days. Actually peaks earlier than that if you mat it from 1500rpm or so, but the torkz just spins the wheels up
Threads: 141
35
your car sounds so good when you come off boost
Threads: 18
Does sound well that pellowe, the plasmas make it difficult to see whats going down. The GT20's dont appear to take long at all to come on full blow... Think i'll take a vid of 30-70 in 3rd now im running dumb boost but i time mine around 6 seconds with a change into 3rd gear, think i hit the mapped in rev limiter in 3rd at 4200 there, need to get my map tweeked again really but ive got to be happy with that on this set-up, the paddle clutch has definitely improved gear changes for me.
Wheres jonny....
Threads: 198
135
Yeah mine really needs some tweaking but I might empty out the boot etc and go for another run tomorrow. Think I can probably scrape a couple more psi from it safely too.
For the weight it's lugging about at the minute, that's really not that bad I don't think, especially seen as it needs properly tuning. Might try one 2nd-3rd and a 3rd-4th too.
Threads: 343
15
Given 3 thank(s) in 3 post(s)
Get some close ups of the dials if you can?
Weight is a big killer in these cars i think, i can feel a massive difference once my tank is nearly empty compered to when its full.... Carnt wait to get mine gov modded so i can see what it can actually do.
Threads: 4
Cant wait to build another one of these!
http://youtu.be/ZWE5ixKG4Iw
Threads: 343
15
What was the specs on that con67??
Bit off topic but what damage will it cause going to 5,000rpm+ ??
Threads: 141
35
Just timed the sedan at about 7 seconds 30-70. The 2.1 carries on pulling at that rate upto 100mph
Threads: 18
2nd gear launch con? Be good to see a flat 30 to 70 of that.
Ozone whats the gearing like in the 2.1, same as a 1.9?
Threads: 141
35
the sedans using a hdi box
Threads: 343
15
Had my pump gov modded now, still not great on acceleration boosting 24/26psi
http://www.youtube.com/watch?v=LJ5W8CkE5-c
Seems to feel alot quicker when im going though the gears but when i did this vid seems slow as fook, it is on a strong veg mix tho so that wont be helping.
@CJ can you get a vid up of yours?? wana see what its like
Threads: 4
08-04-2013, 08:05 AM
(This post was last modified: 08-04-2013, 08:11 AM by con67.)
(05-04-2013, 11:25 AM)Chris_90 Wrote: What was the specs on that con67??
Bit off topic but what damage will it cause going to 5,000rpm+ ?? Shimmed gov, terranno dvs, e300 merc k14 at 30psi, hdi box.
Mine never threw rods or anything in 4-5years, took that abuse quite alot, but 5k+ is playing with fire in every way id say rods/hg lol
(05-04-2013, 03:05 PM)Arron Wrote: 2nd gear launch con? Be good to see a flat 30 to 70 of that.
Ozone whats the gearing like in the 2.1, same as a 1.9? Didnt launch at all mate just booted it a mph or 2 below 30 in second.
Threads: 124
26
Car Model/Spec: Megane DCiR
How do i upload on youtube? Will it work if i upload from photobucket?
Ive only got one from other week with leaking manifold which i dont make 60 just hit 55 then hard on brakes as some fucker pulls out lol
Will try get one tonight on way home n sus uploadin via youtube buddy
Just go to youtube and hit 'upload'....
You do need a gmail account though if you dont already have one. In my experience the photobucket videos never seem to work properly so you're better off with youtube...
Threads: 343
15
(08-04-2013, 08:44 AM)CJ_Derv Wrote: How do i upload on youtube? Will it work if i upload from photobucket?
Yer you need a gmail account easy to sign up tho, but u can put it on photobucket and link put a link to the vid on here to
Threads: 124
26
08-04-2013, 09:04 AM
(This post was last modified: 08-04-2013, 09:09 AM by CJ_Derv.)
Right sussed it i had a gmail account how do i get the link onto here then? Bearing in mind in on samsung S3
Ive only the 30-55 with leaky mani but IMO doesnt seem too bad for 2100revs on a laggy turb
https://www.youtube.com/watch?v=S3U3w8oN...ata_player
Threads: 343
15
(08-04-2013, 09:04 AM)CJ_Derv Wrote: Right sussed it i had a gmail account how do i get the link onto here then? Bearing in mind in on samsung S3
Looks alot quicker than mine just on that small pick up, do a propa one if you can  30-70
Threads: 124
26
It picked up slightly better than that now will do one tonight and will do one from second and show you difference that buildup makes on mine, just remember im running a 15g not a 13t so could make a slight difference although not much
Threads: 178
28
Car Model/Spec: HDi!
http://www.youtube.com/watch?v=0f03XfRZxjs
That was with a chronic boost leak and i had 2 passengers... one had a massive head
Threads: 18
Sounds epic CJ. Looks like it pulls well once its on blow
Threads: 124
26
(08-04-2013, 09:29 AM)Arron Wrote: Sounds epic CJ. Looks like it pulls well once its on blow
Il defo get another today after work n upload tonight does sound epic de-filtered and with stainless pipe with just backbox
Everyone says sounds mint from behind but never heard it frrom outside car may have to get someone drive it so i can hear it
Threads: 124
26
Threads: 343
15
Looks good CJ really dose sound good de-filtered, weight is a big killer in these, mine feels like it goes like fook now my fuel tank is nearly empty
Threads: 124
26
I duno if its just me but does anyone elses seem perkier at times than others, this wasnt a bad run but felt like it had more poke this morning but it was colder and denser
Threads: 198
135
Well theres your answer cj, every 10 degress drop in charge temp equates to something like a 3percent increase in power, at least with NA motors anyway
Threads: 124
26
09-04-2013, 08:44 AM
(This post was last modified: 09-04-2013, 08:44 AM by CJ_Derv.)
I though so ive an amazing drive to and from work over top roads n theres a good straight so will do the 30-60 again in colder conditions and compare
And beed to dyno this again now its runnin right
(09-04-2013, 07:15 AM)Chris_90 Wrote: Looks good CJ really dose sound good de-filtered, weight is a big killer in these, mine feels like it goes like fook now my fuel tank is nearly empty
But the trade off there is that the rear end is a little slipperier due to lack of weight over the beam....
Anyway, dunno why you guys complain about lag on XUDs....this is lag...
http://www.youtube.com/watch?v=umYosXIvr...e=youtu.be
Think I broke'd it....
Threads: 343
15
Threads: 198
135
09-04-2013, 02:28 PM
(This post was last modified: 09-04-2013, 03:00 PM by Piggy.)
http://www.youtube.com/watch?v=MGIT49N86...e=youtu.be
das mine...
kkk turbo at 26/27psi, 11m pump, gov modded, lda ground, tmic, buggered head and quite sure despite the 26/27psi that I have a boost leak
not sure if its much cop
just to add, 100% veg oil!
30-60 is roughly 5seconds
i think the 30-70 is about 7.3seconds
