Fitting cooler tomorrow
Thumbs Up
Hey guys I'm fitting the fmic on my hdi tomorrow morning, got any pointers to make the job go smoothly?
If its your first FMIC install I'd make sure you have the whole day to do it, start nice and early (9~10) and allow 4~10 hours providing you have everything you need.
Have you already worked out your route etc?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
I've got a rough idea due to people's pics but I have everything I need for the install, I need to cut some pipes when I get to the garage but that's it.
As said make sure you have plenty of time, my first time took some right doing but i got there in the end..... was rather stressful lol
The original pipe is a complete pain to get out. Tryin to think what else there was
(01-04-2013, 01:46 PM)PE02KHG Wrote: The original pipe is a complete pain to get out. Tryin to think what else there was
IIRC its easier to cut it out then "remove it".
S14 Zenki Build
this i had to cut mine as well.......
I just pulled, lots.
As above haha.
Don't try and fit anything before you've got your routing sorted, make sure pipes fit the gaps comfortably etc. Take care to get a good seal on each connection as you go, trying to chase phantom boost leaks afterwards is a nightmare.
That pipe is a pita.
Also the inlet elbow is a knuckle scraper, and before fitting the 406 elbow make sure you clear all the gunk and sludge off for a clean contact
S2 HDi >click<
154bhp
280lbs/ft
(01-04-2013, 09:50 PM)Arron Wrote: That pipe is a pita.
I also recommend not cleaning the elbow in your kitchen sink, or you'll have to spend ages the next day cleaning the sink, taps, wall, floor and the bloody kitten which decides to walk through it all.
[Image: sig-3.jpg]
Rofl
Proper lold, boss is looking at me funny now...
Well it's not happening today which I'm gutted about because my dad is busy so he can't help. Got to wait ages again now
Gutted. Cant you mount the cooler and just line it up to an extent?
S2 HDi >click<
154bhp
280lbs/ft
(01-04-2013, 09:09 PM)Poodle Wrote: As above haha.
This! Trust me!
lmao that's too funny
unfortunate to hear you had a dirty pussy...
(02-04-2013, 10:15 AM)Arron Wrote: Gutted. Cant you mount the cooler and just line it up to an extent?
What he said, mtfu and get on with it! Wink
yer do it in 2 parts fit the cooler to the front run the pipes in to the engine bay then put it back together and come back another day and remove the old pipe of the back of the engine and run the rest of the pipe work thats how i did it any way, was easier that way as once you got your pipes from the cooler in to the engine bay you can play around with the route of the pipes to make it sit exactly were you want.
That's a good idea thanks guys I'll get on it tomorrow! Got another day off tomorrow so I'll mount it. How the eff do I take the bumper off?
(02-04-2013, 02:34 PM)aaron_one Wrote: That's a good idea thanks guys I'll get on it tomorrow! Got another day off tomorrow so I'll mount it. How the eff do I take the bumper off?
2x 10mm bolts behind bumper, Get arch guards out of way on drivers side there is the washer bottle you can leave it in place and get your hand up behind it fiddle to get the bolts if not its only two bolts to take washer bottle off. really easy to do just can be fiddly to get the socket on the bolts.
The 4 red circles are were the bolts come though the slam panel they are diagonal from each other
[Image: 306blue371_zpsf6030a93.jpg]
So to clarify, four 10mm nuts lol.
(02-04-2013, 08:53 PM)Poodle Wrote: So to clarify, four 10mm nuts lol.
I noticed the failure but wasn't sure whether to point it out or not Huh
Yer sorry 2 each side = 4 10mm nuts. lol
However if your car has ever been 'repaired' by a bodyshop...you'll probably find theres only 2 nuts left holding the bumper on...which will be loose. And the washer bottle will be held on with the wrong sized nuts which have rusted so much you have to smash the washer bottle off and chuck it in the bin.... Don't forget its a 306, nothing is ever as simple as it should be. lol Oh and yes, thats exactly what happened when I wanted to take my bumper off last week.... Doh
After previously owning a few 306's did you not bother to check something like that before you bought it tom!?
My bumpers only held on with two nuts... easy access in case i pop a boost pipe... Anyway any progress on this aaron?
S2 HDi >click<
154bhp
280lbs/ft
Turns out this cooler project won't be happening as I've just bought a 2008 ford fiesta st Smile
Ill buy the oil cooler of u mate
wrong thread!
  oil cooler fitting rd070707 1 961 20-01-2014, 08:49 PM
Last Post: Jimbo
