29-03-2013, 11:06 PM
Thought id upload a couple of pics of my de backbox me and my mate made up the other day ...
Basically what we did was unbolt standard backbox... cut flange off original backbox and weld it onto a steel pipe about the same length as the backbox.. then temp fit it to see where abits its going to line up ... cut the hangars off box or if not long enough use some bar.. then mark with chalk wherabouts thell go .. weld them on and with a bit of bending should be all sorted ....weld a stainless tip in if you like and there you go .
If u ever want to go back to original exhaust ..a new one will just bolt straight on
Heres some pics ..
Heres some pics ..
