clutch help
Changed the clutch in the dt today when i was putting in new gear box oil i found a leak from the driver side drive shaft any ideas what I've done wrong
Did you replace the drive shaft oil seals?
My gess is drive shaft oil seals as frosty said
No i didn't Sad
will get some today and have a look
thanks
I had same problem get new seals, i got pair off ebay for a tenner just means draining box n pop shafts out again
[Image: J5hxCcC.jpg]
Yea will go down the local now.
Looking at it though idont think the driveshaft is in properly the car is driving though Confused
Its got to be in id have thought i had one side leaking but changed both to be safe
Turned out i hadnt put the drive shaft all the way back in feel like a cock now lol
