It's a xud9 ph2 with big hybrid turbo, fmic, 11mm head, oil cooler. Changed few headgaskets, new head and skimmed and everything. The temp stays at 80 degrees. After a bit of coaling, the coolant level light comes on while running slowly at 2000rpms, a bit of revving and the light goes off. There's water coming out from the coolant reservoir cap. Could it be the cap that makes such a huge difference in letting the pressure out of the system?
HELP! Pressure in the cooling system
12-03-2013, 10:52 AM
Has it been bled properly? Sometimes cap can let coolant out, as they do have a little pressure as coolant is mixed with water which naturally expands with heat, also is the heaters hot? I replaced a few head gaskets on blaze and found the matrix was blocked and caused each gasket to blow due to bad circulation
12-03-2013, 01:57 PM
It's been properly beld. Heaters hot and the heater matrix is conected.
12-03-2013, 03:17 PM
have you pressure tested the cap to see if its holding pressure or just letting water out after its expanded? Might be worth a few £'s to buy anew cap ??
![]() the smokey old bus that sounds like a tractor...
12-03-2013, 04:21 PM
sounds like one of three things...
air lock rad cap water pump internal failure Wishes for more power...
12-03-2013, 04:46 PM
Looks like its the head gasket again. I think the head wasn't skimmed well so doing it again.
12-03-2013, 04:59 PM
just an fyi...
a friend had similar issue with a xud xantia...turned out to be the head...there was a run of dodgy heads...get it pressure tested Wishes for more power...
16-03-2013, 12:19 AM
Did you have it pressure tested last time you did the head a lot of people try to save money by leaving this important process
20-03-2013, 12:04 AM
So it actually was the head. It was blowing through the pre-chambers. Now is runing fine. Had some problems with a stuck injector.
http://www.youtube.com/watch?v=pWOJvmVhF...e=youtu.be |
cooling pressure issue(video inside) | bashbarnard | 4 | 1,829 |
02-09-2015, 02:44 PM Last Post: bashbarnard |
Cooling system issues | Mitch | 6 | 2,310 |
14-01-2014, 09:01 PM Last Post: Mitch |
Are cylinder pressure and boost pressure inextricably linked | Flynn | 55 | 12,425 |
18-01-2012, 08:19 PM Last Post: Matty |
