19-10-2012, 04:34 PM
I might mask mine up differently just to go against the grain...spare lights turned up today!
Valeo black mask guide!
19-10-2012, 04:45 PM
@gareth gonna look good mate!
Get some pics of the clusters up when you've put them on. C.a.r ^^ see it really is easy, get em done mate!
20-10-2012, 06:47 AM
will do mate......should have everything on by next weekend
26-10-2012, 06:23 PM
photos as promised......
and the rear clusters....
27-10-2012, 11:17 PM
When the headlight is in the oven does it go lense up or horizontally like it would be when in the car?
27-10-2012, 11:27 PM
Looks a good job that gareth7, Rear tints aren't too much either!
Just lay them flat as they would be on the car jay8086, probably the only way you'll get them in the oven anyway!
Thanks oil-burner......my first attempt at the rear clusters ended up a little........illegal looking and dangerous when I test fitted them and had a look at the lights when they were switched on. It was a case of 'oh shit, best get the thinners out and start again' lol
07-02-2013, 12:49 PM
Can I ask what sealant people are using to re-seal them? I have some black all-purpose all-weather sealant from B&Q which was meant for something else - will this do the trick?
07-02-2013, 01:40 PM
(07-02-2013, 12:49 PM)C.A.R. Wrote: Can I ask what sealant people are using to re-seal them? I have some black all-purpose all-weather sealant from B&Q which was meant for something else - will this do the trick? Yeah mate that will work! Id go for black or clear if I did them again.
19-02-2013, 05:49 AM
(07-02-2013, 01:40 PM)Oil-burner Wrote:(07-02-2013, 12:49 PM)C.A.R. Wrote: Can I ask what sealant people are using to re-seal them? I have some black all-purpose all-weather sealant from B&Q which was meant for something else - will this do the trick? I've just started to use black sealant on a set I finished over the weekend, you can get a really neat finish with it.
19-02-2013, 06:44 AM
Tiger seal is what i use!
Black mask Service
20-02-2013, 02:29 AM
did you remove all the wiring from inside the light before putting into the oven??
11-03-2013, 08:12 PM
Fantastic guide just started my black masks
i used the heat gun method with awesome results car looks evil as foook
12-03-2013, 12:03 AM
You did very well if you managed valeos with a heatgun mate, you sure theyre not depos?
Yeah makes a massive difference, I love mine!
Got Lucas on them either way result
I used to do an adjuster replacement service and lens refurb service for bmw Angel eyes so heat gun is the best method for not causing any damage if i am honest
12-03-2013, 07:59 AM
Lucas???
Possibly so but honestly valeos are stuck like shit to a blanket, even in the oven you only have a small bracket of time to get them open in one go. Plus if you're careful you wont damage them anyway, mine are bang on.
12-03-2013, 08:21 AM
Yeah man deffo Lucas lights. Either way bud top marks for your guide was spot on cheers
12-03-2013, 08:26 AM
Hmmm never seen lucas crystals before tbh.
Nice one mate, glad its still helping people out.
22-03-2013, 08:45 AM
Are all crystal lights valeo's?
22-03-2013, 08:58 AM
(22-03-2013, 08:45 AM)Tallguy_2 Wrote: Are all crystal lights valeo's? Nah original ones are but depo do pattern ones which you find are quite common. Much easier to open up but I don't think they fit as well.
22-03-2013, 09:04 AM
That's right. Depo fitment is slightly off where it meets the wing.
22-03-2013, 08:55 PM
I started this to find I have one depo and one valeo. How does the process for depo differ?
22-03-2013, 09:44 PM
You can use a heat gun to open them, ive heard you can even do it with a good hair drier.!!
Tbh id have a go with the valeo and if you get on ok look for another instead of having one of each.
22-03-2013, 10:18 PM
Sweet guys, how do I tell which I may have?
Thanks for your help
22-03-2013, 10:37 PM
one fits right and the other doesnt
23-03-2013, 03:13 AM
Look on the lens where the bonnet would over lap on the top of the light......it'll say Valeo in small writing.
23-03-2013, 01:00 PM
Mine don't say valeo, hmmm I'm gonna have a crack!
23-03-2013, 01:39 PM
Rubbish picture but hey
Yeah i managed them with a heat gun. Used to refurb BMW e39 headlights, replacing the adjusters you needed to crack them open to acess them. and the heat gun method is something that i used all the time but the oven method is also a good one next step is to go over the lenses with 1000, then 1500, and finally a 2000 grit sandpaper to make them all nice and new |
