TD04 Exhaust Studs?
TD04 Exhaust Studs?
Been looking at the turbo and noticed that it seems to be missing a stud.
[Image: zqdjvoXh.jpg]
That hole on the right is threaded, should I try and get a stud to go in there? I've just paid for my adaptor plates so can't bolt that on to see if it'd be ok without. Intending to get it fitted as soon as they arrive so if possible want to sort this (possible) issue out while they're in the post.
Dont worry about it pal just get a nut and bolt large enough and bolt it through the plate and hotside jobs a gooden
[Image: J5hxCcC.jpg]
Will this be ok to go in there? I would use CJ's suggestion but where it is there is not room for a bolt head or nut.
http://www.ebay.co.uk/itm/MANIFOLD-STUDS...2a1f1a7b87
A google has revealed that should be the thread and pitch size (annoying different pitch to all the Peugeot bolts I have) but I'm worried about the grade as it's only 4.6.
Try and extract one of the others and put it there instead then bud
  Exhaust and inlet manifold spacers and studs andyyy 1 2,087 15-03-2015, 01:51 AM
Last Post: zx_volcane
