For that, I come from Galicia, Spain, and not English, I have to use a translator, so siemto the spelling mistakes. My name is Ivan, my first car was a 306 1.6 90cv, dump it after I bought my 406, and since then dismounted and mounted him and almost everything. . . is a 2.1 td, and I am very happy with it, but not with the epic, normal, went very very bad. I'm from the 406 club, if someone wants to go leave my presentation there :oops:
You must register to see. . .
http://www.club406.es/foro/viewtopic.php?t=4190
Well, for those interested get a list of repairs and changes that and done it at home, and with the help of my fellow forum 406, where and learned lots of things and I hope to help around here, although I will be difficult for the language.
Changing the clutch.
Valvulina change gearbox and differential checkpoints.
Recess flywheel weight.
Increased turbo pressure of 1.2 - 1.3bar.
Eprom of grostoto v6
Damper pulley rupture, and traces of glue to the distribution, broken distribution, pulley camshaft, rocker arms and rocker arm broken Apollos. repair
Changing distribution, water pump and thermostat.
Change hydraulic tappets and cylinder head cover gaskets.
Clean egr admission and void.
Carry injectors cleaned and recalibrated.
Change all together epic pump at home.
Numerous changes as silenbloks, ball joints, engine blocks, rods, bellows, ect. . .
Various changes suspensions.
Montage coupe dashboard plastic.
Change A.A manual climate control.
Cruise control installation.
Installation board computer.
Brembo coupe.
Etc etc, most things. . .
All approved, because of our political thieves.
I put some pictures of the evolution from entering the club406 forum and started to save photos.
I hope you like :cheesy:
![[Image: imagen2011.jpg]](http://img641.imageshack.us/img641/9061/imagen2011.jpg)
![[Image: imagen2401.jpg]](http://img641.imageshack.us/img641/3217/imagen2401.jpg)
![[Image: imagen203.jpg]](http://img706.imageshack.us/img706/5613/imagen203.jpg)
![[Image: imagen243g.jpg]](http://img202.imageshack.us/img202/8631/imagen243g.jpg)
![[Image: imagen245.jpg]](http://img706.imageshack.us/img706/8715/imagen245.jpg)
![[Image: 25062010427.jpg]](http://img171.imageshack.us/img171/417/25062010427.jpg)
Finally, goodbye to gray wood. . .
![[Image: 08092010550.jpg]](http://a.imageshack.us/img713/8571/08092010550.jpg)
![[Image: 08092010549.jpg]](http://a.imageshack.us/img839/7508/08092010549.jpg)
To climate change
![[Image: 15012011664.jpg]](http://img14.imageshack.us/img14/2458/15012011664.jpg)
![[Image: 29012011688.jpg]](http://img713.imageshack.us/img713/9584/29012011688.jpg)
![[Image: 27012011683.jpg]](http://img444.imageshack.us/img444/7889/27012011683.jpg)
The brembo
![[Image: 10062011744.jpg]](http://img806.imageshack.us/img806/2720/10062011744.jpg)
in task
![[Image: 16062011792.jpg]](http://img109.imageshack.us/img109/9271/16062011792.jpg)
Lucas epic joins
![[Image: 20062011826.jpg]](http://img24.imageshack.us/img24/1667/20062011826.jpg)
![[Image: 20062011828.jpg]](http://img703.imageshack.us/img703/2583/20062011828.jpg)
Modification of defense and the boss
![[Image: 181220111060.jpg]](http://img12.imageshack.us/img12/5305/181220111060.jpg)
After painting the car, which made him miss his 13 years, etaba very bad, but always care where I park.
![[Image: 200120121105.jpg]](http://img856.imageshack.us/img856/9609/200120121105.jpg)
![[Image: 020220121111.jpg]](http://img846.imageshack.us/img846/2619/020220121111.jpg)
These are recently
![[Image: p3300049.jpg]](http://img580.imageshack.us/img580/1889/p3300049.jpg)
![[Image: p3300057t.jpg]](http://img26.imageshack.us/img26/4084/p3300057t.jpg)
![[Image: p3300058.jpg]](http://img600.imageshack.us/img600/3074/p3300058.jpg)
![[Image: p3300053.jpg]](http://img716.imageshack.us/img716/8062/p3300053.jpg)
Well so is more or less like this now.
This is a picture that started long ago, but I do in spare time, now I have very little, have when I find a free moment. . .
![[Image: 030520121180.jpg]](http://img855.imageshack.us/img855/2041/030520121180.jpg)
![[Image: 030520121181.jpg]](http://img848.imageshack.us/img848/8725/030520121181.jpg)
![[Image: 030520121184rj.jpg]](http://img443.imageshack.us/img443/9913/030520121184rj.jpg)
ufff and all this change together collectors and exhaust studs, because of losses with oil. . . that operates more dodgy
![[Image: 240520121193.jpg]](http://img220.imageshack.us/img220/3756/240520121193.jpg)
![[Image: 240520121189.jpg]](http://img521.imageshack.us/img521/4933/240520121189.jpg)
![[Image: 240520121190.jpg]](http://img841.imageshack.us/img841/6904/240520121190.jpg)
I hope you have enjoyed the life of my 406.
A greeting from Galicia - Spain
Brembo coupe.
To climate change
The brembo
in task
Lucas epic joins
These are recently
