04-03-2013, 08:27 PM
basically all in the title!
would no oil cause car to cut out?
04-03-2013, 08:28 PM
it'd cause it to die . .
Depends if it siezed the engine. Otherwise probably not as tu engines have mechanical lifters as opposed to hydraulic
04-03-2013, 08:35 PM
Yeah probably, it'd seize up and cut out, Might start again once it's cooled but basically the damage will have been done.
04-03-2013, 08:40 PM
The engine would have got very noisey before siezing though so if it did good chance the engine is knackered now
04-03-2013, 08:43 PM
This is a bit of a ridiculous thread tbh.
Would you die without water? Yes Would you burn yourself if you stuck your hand in a fire? Yes ...
Astor 'X' 4 GTi6-6 - SOLD! ![]() '08 LY Renault Megane RS 230 F1 Team R26 - GONE '56 BMW Z4 Coupe 3.0si Sport - SCHWIIIING!
04-03-2013, 08:45 PM
Would your engine tap if it was a GTi? Yes.
04-03-2013, 08:47 PM
Yeh with no oil its fairly screwed :/ My 1.4 did 5 miles after the sump plug fell out... it survived and was all fine and was scrapped due to oil leaks and needing a headgasket :/
04-03-2013, 08:48 PM
Would your XUD splutter to life on a cold morning with a cloud of smoke? yes
04-03-2013, 08:54 PM
Would samass bum you given even the slightest opportunity? Yes
04-03-2013, 09:01 PM
well i filled it up with oil and its fine! for now...
04-03-2013, 09:25 PM
I'm holding my breath for the next thread "Would no fuel cause car to cut out?"
04-03-2013, 09:29 PM
be prepared for losing engine internals lol
04-03-2013, 09:41 PM
Would driving without properly torqued wheel bolts cause the wheels to fall off? Ask Matt.
04-03-2013, 09:45 PM
04-03-2013, 09:54 PM
(04-03-2013, 09:01 PM)Welshdrg Wrote: well i filled it up with oil and its fine! for now... As I said in chatbox, I expect it was coincidence that it cut out. The TU isn't smart enough to realise low oil pressure will kill it afaik. Plus, how many litres of oil did you 'fill' it with again afterwards? I'm betting it wasn't dry....
05-03-2013, 12:03 AM
Would eating toxic crayons result in long lasting and irreparable brain damage? Ask Niall
05-03-2013, 12:08 AM
(04-03-2013, 08:54 PM)Ed Doe Wrote: Would samass bum you given even the slightest opportunity? Yes Would samass bum you given zero opportunity? Yes... 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
05-03-2013, 12:50 AM
Would no being in the car with your keys in your pocket mean you car would drive its self? Unless your grant, no.
05-03-2013, 01:12 AM
it wasnt dry i only thought it was the oil becauswe i seen the oil light flick on ....about 2-3 litres
05-03-2013, 06:35 AM
(05-03-2013, 01:12 AM)Welshdrg Wrote: it wasnt dry i only thought it was the oil becauswe i seen the oil light flick on ....about 2-3 litresYou might be very lucky then. As much as your question was sincere, it was a little bit silly buddy, might want to use common sense in the future. ![]() I Black mask Crystal headlights, check out my Thread
Black mask Service
05-03-2013, 08:10 AM
(04-03-2013, 09:41 PM)Scott Wrote: Would driving without properly torqued wheel bolts cause the wheels to fall off? Ask Matt. I hate you. Would driving with a partially hydro locked engine cause the rods to throw? Ask.. Oh wait ![]() TEAM CONROD SHITTING RALLYE!
05-03-2013, 08:12 AM
We're not ripping it out of you by the way, we can't expect everyone who joins up to be mechanics or engineers and be able to dismantle an engine with a paperclip, so don't take it personally
05-03-2013, 08:28 AM
Would asking any question about any other car cause Tom 306 to reply with a sentence hinting at his predisposition to bumming golfs, as well as his longstanding distrust of 306s....
05-03-2013, 08:53 AM
(05-03-2013, 01:12 AM)Welshdrg Wrote: it wasnt dry i only thought it was the oil becauswe i seen the oil light flick on ....about 2-3 litres Ah there was loads left in there then! ![]() ![]() Incidentally, golfs don't often leak oil, whereas 306s almost always do... /dunnowhatedsonabout
05-03-2013, 09:05 AM
(05-03-2013, 08:53 AM)Toms306 Wrote: Incidentally, golfs don't often leak oil, whereas 306s almost always do... /dunnowhatedsonabout ![]() There are a couple of mk4 tdi's round my way; every time I see them start, puffs of blue, and blue haze all the way up the road.... ![]() ![]()
05-03-2013, 09:31 AM
Can't say I've seen a blue smoking mk4 (thats a mk2 thing lol), but plenty of coal usually as they're driven by old people that don't clear them out.
05-03-2013, 02:17 PM
Because it's a 1.4. Its probably got a f*cked coilpack or something tbh.
05-03-2013, 02:44 PM
Do you need to regularly change your racoon filter on agti? Ask Ed tap tap doe.
