Threads: 71
Car Model/Spec: 205 dt
basically not something I've ever looked at but need to change the camshaft to later style xud one to be able to relocate the vac,
any advice help what the f*ck I need to do? cheers
Threads: 71
26-02-2013, 11:16 PM
(This post was last modified: 26-02-2013, 11:17 PM by kernow_joe.)
hmmm if I'm doing that may aswell drop a 1.9 in, cost wise anyway, was hoping to see what I can do with the 1.8 though
Threads: 71
Anyone else got any input/ advice?
Threads: 90
No problems at all Joe changing the cam...changing the caps is where the problem is or over tighening the bolts...just makes bearings pick up / cam break....the XUD 9 cam will fit your xud7 but cant reember if the pump bolts on / oil feed is there?
Tbh id just drop an XU9 in it....
Threads: 71
27-02-2013, 08:38 PM
(This post was last modified: 27-02-2013, 08:54 PM by kernow_joe.)
nice one cheers Dave, is annoying only want to be able to fit a vac pump on the end of the damn thing! bit worried I may kill it though bit more then I've played with before.
Will search around do a bit more reading I reckon
pump will bolt on grabbed one from scrappy the other day and eyed it up, bolt holes are all there, and think need to remove an allen key to open oil feed,
well it seemed a cheaper/easier option to keep the 1.8 in there and the engine seems so good seems a shame to scrap it
Threads: 71
its sounding an easier job to drop a xud9 in ....
Threads: 90
If you need an XU9 I think i might know of one being broken.
Threads: 71
oh really? this sounds interesting, if you could find out that would be amazing
