cooling fan issues
cooling fan issues
Hi,
Having some issues with my cooling fans on my HDI with AC, they dont kick in at all, in traffic the otherday the car neearly hit 100c with no fans, so far ive checked all the fuses in the car and in the box near the battery, pulled the plug off near the windscreen washer fluid bottle and bridged pins 1 and 3, still not working with the ac switch also tried pins 1 and 2. Should i get new relays next or am i missing something i looked at the relays they werent loose , have no idea how id check them
any ideas what i should do next ?
I dont really know what to do next but for the time being when the temp starts to get hot whack the heating on full blast that will bring the temp down.
common on these are the fans going open circuit if one fan goes open circuit you loose the slow speed
but one fan will run on full speed
you need to work out if the fans are actualy ok or if they are broken electricly
also look at the relays they may be corroded internaly
this might help too
  Cooling fan issues, cant find the bitron controller Leedunn86 5 4,599 30-04-2013, 08:57 AM
Last Post: Leedunn86
