Old Radiator
Old Radiator
Smile
Well I was quite surprised when I pulled the old radiator from the 'Turbo, it turns out that it was quite well rusted:
[Image: P1010042_zpsa7cb8b86.jpg]
The holes were poked with a screwdriver just to give you an idea of how rusty it was!
I didn't realise the radiator metal was silver, I thought it was black when new! How wrong was I:
[Image: P1010043_zpsd9ac6f8b.jpg]
I thought replacing the rad was a relatively easy job, I would say it was about 2/3rds as hard as a cambelt for comparison, although it is my first radiator job.
Some are black when new mine was but others were silver. Good job.
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Good work Smile How did you bleed it?
2/3 as difficult as a cambelt...seriously!?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
^^^^yeah this....
I hope you didnt think you HAD to removed the bumper?!
I'm not slating for removing the bumper, doing that makes it much easier. Just that its not hard, few pipes to remove and its pretty much out.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
yeah defo...I would take 2 rad jobs over a cambelt anyday
(22-02-2013, 07:15 PM)Piggy1987 Wrote: yeah defo...I would take 2 rad jobs over a cambelt anyday
I would rather do the cambelt I bloody hate changing rads on these. All cos of that bottom hose, it always wants to leak, or clips snap off or the o ring twists up or I cut my bloody handsHate
/rant
HDi Cabby Project Click
haha...
adapter removed on all my pugs... so much easier with a jubilee
(22-02-2013, 06:18 PM)Andy325i Wrote: Good work Smile How did you bleed it?
I stuck a hose in the top and opened the bleed points. Best method IMOIdea Then I bled some more out to put the antifreeze in. But I think I didn't get all the air out because I went to get some more antifreeze and then pour it in and the water level seems to have dropped all by itself and I'm certain there are no leaks because I ran it whilst the front end was off to checkUndecided So somehow it appears to have self bled itself! Suits me, although I can't see how that's possible if the bleed valves are shut.
Quote:I would rather do the cambelt I bloody hate changing rads on these. All cos of that bottom hose, it always wants to leak, or clips snap off or the o ring twists up or I cut my bloody handsHate
/rant
Yeah tell me about it! All it takes is for a clip to snap then you've got to replace the whole hoseUndecided It is especially easy for that to happen in the cold when the plastics are brittle.
(22-02-2013, 09:34 PM)Piggy1987 Wrote: haha...
I think this is the way forward.
Did you just cut the end off and jam it over or use a different hose?
