Threads: 13
Car Model/Spec: ph2 dturbo
Bought some 17inch challengers off a scrap 307 for £60. The current tyres are 205/50 17 and with 10mm spacers on front still touch my coilover springs. Any ideas on spacer size needed. My coilovers are ta tecknicks wound all way down with helper spring still in . Any help much appreciated
Threads: 130
82
Car Model/Spec: 106 GO-NAD
i thought they needed atleast 15mm on the front?
Threads: 132
4
Car Model/Spec: 305 and 306 HDi's
Given 6 thank(s) in 6 post(s)
205/40/17 tyres might help
Threads: 13
Someones giving me 16mm spacers to try. Hopefully that will solve it. Also getting smaller tyres
Threads: 183
20
Given 8 thank(s) in 8 post(s)
10mm spacers minimum but you need 40 tyres. I think oilbuner is running 45 tyres.
I know my 17s on 40s were close.
Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
Tyres are too big. I run 205/40's and with 10mm spacers
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 24
2
Car Model/Spec: 306
Yep ditch those 50s tyres.........
Threads: 13
Cheers the help guys. Hoping they will suit my phase 1 better than clones
Threads: 56
19
Car Model/Spec: Moonstone HDi
No im running 40s too, 50s wouldnt even fit under my arches
Threads: 38
2
I hav some 2x 10mm spacers, and longer bolts going if you need some,
Threads: 541
124
Ideally you want spacers a little wider, the challengers ate ET31 and the 306 is designed for ET18 but a little lower than that looks good so 15mm is fine.
Tyres with a lower aspect ratio will also help because although the tyres themselves wont actually be narrower you have less sidewall height and so less sidewall bulge under the air pressure and im guessing that your only just rubbing on the bottom collar.
Threads: 13
It touches on the spring of the coilover. Got 10mm spacers as it is and it touches. Gonna try some 16mm spacers see if it helps
Threads: 58
3
Car Model/Spec: Loads
Given 9 thank(s) in 9 post(s)
Which bit, the body or the adjuster? if the latter buy a shorter spring
