Threads: 24
Car Model/Spec: 306 Meridian 1.8 16v (Phase 3)
Given 2 thank(s) in 1 post(s)
Has anyone got a spare [working] airbag ecu preferably out of a 2001 phase 4. It needs to be the one that does side airbags as well as the one out of a '99 with no side airbags is different. Cheers for any help / offers.
Threads: 56
19
Car Model/Spec: Moonstone HDi
Best pm ed doe think hes the only one with a phase 4 iirc
No such thing as a ph4 mate. Ignore anything ed says. His is really just a ph2 with botoxed head rests
Threads: 24
Need a bit of advice on what number written on the unit is the actual part number. In a box at the top is 550 86 45 00, pretty sure that's the part number but underneath that is another number that seems unique from what i've seen i think its the serial number, but its also got AK written on the right hand side that looks like a date stamp. As in AB is older than AK, and AQ is newer. How correct is the above and how important is the date stamp if the part number matches?
I'm sure the unit is shot as PP2000 says ECU has not replied, but the dash reacts as normal. Airbag and pretensioner lights come on for a few seconds then go out so does that mean the car thinks it works or that it works and the problem lays elsewhere?
Threads: 16
Car Model/Spec: 306 GTI 3.0 V6
Hi mate i got the ecu from phase 3 for side air bags. (seat)
Pm me woth an offer
PP doesnt always connect to these ecus. You need to try several times. Also try with the engine off, engine on. Eventually it will work.
