14-02-2013, 08:15 AM
Thinking of inter-cooling the daily to make the work commute a bit more fun, but also as cheap as possible, would this be ok?
Suitable Hdi cooler?
14-02-2013, 08:29 AM
I'd say it was a tad too small.
And depending on the length the ic pipes might not fit. Got any dimensions?
14-02-2013, 08:32 AM
Core of 70 x 16 cm
I've seen that sam, but its 3 times the price
14-02-2013, 09:33 AM
I brought a kit on eBay 130 comes with all the bends you'll need
14-02-2013, 09:35 AM
Have you fitted it? Were the clamps supplied and any good?
14-02-2013, 10:14 AM
Thats a focus st intercooler isn't it? They don't fit, at least not without some effort.
Try for something else, maybe a mondeo tdci one someone on the xud side is using one and if it's good enough for them it'll be fine for us
Don't fit for what reason? Too wide? I think it's from a tdci, but it does look a lot like a st one, maybe just smaller.
Should add, this is going on a 206. I think ST have an 11 row, this is a 7 row. I have seen the one on the xud, which made me think this would be fine
14-02-2013, 10:41 AM
Well I had that intercooler and tried fitting it and the inlet pipes just don't line up with the slam panel, would involve fair bit of cutting etc at and was just alot easier to find a different intercooler, go for oem intercoolers though more fun/cheaper.
not sure how different the front end is on a 206
14-02-2013, 11:03 AM
Looks like you'd face same problem as 306 ,passenger side you'd be fine but drivers side the angle of the inlet wouldn't work as stock
14-02-2013, 05:20 PM
Clamps were ok as long as you don't go mad tight other wise they start to slip I am happy with it
14-02-2013, 06:29 PM
For reference, one that size is plenty big enough for stage 2, anything bigger will usually just cause more lag and pressure drop with no gains to speak of.
