Threads: 129
11
11-02-2013, 08:01 PM
Just stumbled across this on youtube. Apparently it's making 206bhp and judging by the smoke it's certainly got the fueling for it!
http://www.youtube.com/watch?v=t4FvlH0ukLM
Stage 2 XUD Sedan
I'm really no expert with high tuned 1.9 xuds....
but surely thats just wasting fuel?!?!
Threads: 129
11
It's from a laggy turbo, meaning it can't burn the fuel in time, no doubt it's got a massive old turbo on it.
Stage 2 XUD Sedan
Threads: 27
20
Ha ha f*cking hell!! I give the bloke with the camera about a year to live lol
Sounded good for a dirty derv!
Threads: 90
Yet again, another COMPLETELY incompetent dyno operator!
Threads: 71
Car Model/Spec: 205 dt
as said is lag, if driven by someone thats not a numpty they don't smoke so bad during normal driving. notice it all clears once the turbo spools
Threads: 87
48
(11-02-2013, 08:03 PM)Piggy1987 Wrote: I'm really no expert with high tuned 1.9 xuds....
that's an understatment lol . . . . .thing is yes it is bogging down, but the operator is holding it at lower revs, when it gets on full chat it's burning fairly clean . . . .
Threads: 129
11
It's clean as a whistle on boost, I'm quite interested to know the spec of it. Is it anyones on here?
Stage 2 XUD Sedan
surely though that points to a bad pump/LDA setup??
Threads: 71
its due to poor right foot control/ lack of understanding of how to drive a mechanicaly tnued diesel
or that is incredibly hard/impossible to dump the fuel in needed for real power and keep it clean off boost
Threads: 129
11
Not really it points to a laggy turbo in most cases. Mine coals to f*ck if I plant it at really low revs. LDA helps but not buy much, I like to have my LDA wound quite far in as I've been driving XUD's long enough to know how to control it by throttle.
Stage 2 XUD Sedan
yeah....true dat...
my mate has never, litteraly, never driven diesels...
took mine out and was moaning about how crappy it was...but it was driving style mostly...driving it like a petrol...well mostly...it is a bit crappy
(11-02-2013, 08:14 PM)Piggy1987 Wrote: surely though that points to a bad pump/LDA setup??
If you can make a pump have NO smoke at 1200rpm, come on boost at 2300rpm and then put in 200+HPs worth of fuel ALL on the LDA, be my guest...
But as most people realise after pissing about with LDA pins etc, that you may as well not bother, because all that happens is that you make it really laggy, as you've got NO fuel to spool the turbo up with until the LDA drops and with enough tension on the LDA to make it not drop before the turbo comes in, when you mat your foot, you jam the LDA pin, and it just makes for a horrible drive...
Definitely Irish, judging by the fact that it's got TSW Stealths on.... The number plate confirms it too!
Ta Ruan...clearup the braincells falling out my ear as usual
I was making a rather sweeping statement though...
I played it with sound...made a rather big diff...I see what you all saying about bad throttle control and it being clean on boost now...just assumed it was that smokey on boost
Threads: 9
Car Model/Spec: 306 d-turbo
Yeah it's mine I only register on here a few days ago, it goes well but having problem getting more fuel in up high. Also discovered its still got the Lucas injectors in
Threads: 87
48
(11-02-2013, 08:32 PM)MarkHam Wrote: Yeah it's mine I only register on here a few days ago, it goes well but having problem getting more fuel in up high. Also discovered its still got the Lucas injectors in
be good idea to change them . .
welcome
Threads: 289
92
Car Model/Spec: Phase 17 R26
Cameraman clearly died at the end
Threads: 129
11
We need specs!!
Welcome by the way
Stage 2 XUD Sedan
81
welcome and epic!
Threads: 9
Bosch pump with 11mm plunger some modifying with a drill and lathe. intercooler from a transit and homemade 2.5 exhaust
Going to order a devilsown water inj base kit, get decent injectors and that should be it finished
Threads: 48
Turbo? lol
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
11-02-2013, 09:27 PM
(This post was last modified: 11-02-2013, 09:27 PM by Piggy.)
^^^^ yeah coz surely 206bhp isnt just from a modded 11mm and a fat exhaust??
Threads: 41
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
(11-02-2013, 09:25 PM)MarkHam Wrote: Bosch pump with 11mm plunger some modifying with a drill and lathe. intercooler from a transit and homemade 2.5 exhaust
yours?
What spec is the motor?, how much boost etc, stock bloick?
Threads: 9
Yeah.
It's just a standard block with new bearings. About 2.5bar boost. Probably not too long before it explodes
Threads: 129
11
What's the turbo Mark?
Stage 2 XUD Sedan
Threads: 208
60
Given 5 thank(s) in 5 post(s)
We may find out what turbo it is by the end of this thread lol
Threads: 13
Car Model/Spec: Feltspec white ph1 dturbo
wa just about to say, looks while like yours mark, only last time i seen it, it had a spoiler
same turbo i had for a while iirc
Threads: 9
Threads: 208
60
Which is ???? lol
