Rear electric windows
Is it possible to convert my estate rear windows from manual to electric and if so what do I need and how do I do it
id guess you wouid need, Mechs, looms, Relay, switches,
and 2 door cards,
have alook under the centre console see if you have the wiring in place,
if so it shouid be plug and play,
You should have the wiring so 2 motors and window switches and the cut off button.
Not sure if you need a relay or not.
Got all the parts needed here too if you're looking?
[Image: sig.jpg]
Ill see if I have the wiring first where should I look fro the wiring exactly ???
You wouid be best taking a door card off and 'see ing if you have the plugs for the electric motors,
or pulling back the rubber boot on the door loom and check how many wires you have,
You may need door loom's.
as for the switches, check under the rear of the centre console, Rear ashtray area the plugs shouid be there,
but idoubt the connectors will be there in the doors for the elec motor,
You will need the dash relay, Leccy window switches for rear console and mechanisms in the door all the wiring is already three as I've do this with my hdi :-)
Ill have a look in a bit how many wires are there leading into the door if the wiring for the motors is there ?
The electric window wiring will plug into the central locking loom already in the door you'll see it when you open the door, luckily the door I had were the same colour so all I did was add the relay add the switched and plug it in but it should be the same
Door card and mechanism
Mechanism plugs into loom already there for the central locking
I want to do this, do the window motors just fit onto the existing glass?
HDi Cabby Project Click
At home i have got all of the parts needed for a conversion! Thats the two motors and regulators, middle switches and the button for the dash! Had it for years after i bought hem to convert my 1.4 but never got round to it! Offers if anyone wants it all!
I ain't got the wiring for the switches in the center so I can't do this to mine
It should do Undecided under the ashtray panel bit have a dig see of they have slid forward towards the handbrake pal
Ill have another look but I couldn't see em anywhere
(10-02-2013, 12:07 PM)SRowell Wrote: At home i have got all of the parts needed for a conversion! Thats the two motors and regulators, middle switches and the button for the dash! Had it for years after i bought hem to convert my 1.4 but never got round to it! Offers if anyone wants it all!
How much are you looking for, very interested
Got the same setup here, can do it for £50 delivered?
[Image: sig.jpg]
(10-02-2013, 12:13 PM)Willo Wrote: I ain't got the wiring for the switches in the center so I can't do this to mine
the plugs might be stashed under the carpet,
  Rear Windows Cabrio pitpol 0 1,984 20-03-2017, 10:01 AM
Last Post: pitpol
  electric windows sb194114 5 3,699 07-02-2015, 11:14 AM
Last Post: pug306driver
  Rear Electric windows LewisG 5 3,519 29-03-2014, 08:07 PM
Last Post: LewisG
