Threads: 25
Car Model/Spec: dturbo
Hi i have a ph1 dturbo. The key i have has a blip that opens the door without doing it manually, the wee chip inside has broke somewere and it doesnt work now.
How can i fix this?
Can i buy one or use a 2nd hand one that i can program to my car?
81
a blip you say. You mean just a button for remote central locking? Niall may be able to help but im surprised that the phase1s came with RCL if im honest!
81
If anyone knows if it can be reprogrammed it will be Niall!
Threads: 110
20
I can find out how to reprogram the remotes on auto data at work if that helps
Threads: 110
20
I don't know if that 1 will work though as it looks more like a 206 1 even though it says 306
Threads: 11
Car Model/Spec: 1.4 Guffy LOL
I've tried a 206 fob and it didnt work!
Maybe I was doing something wrong but.
Get yaself a new fob/new guts and a new battery...
then:
ensure all doors are closed and unlocked
put the key part in the ignition and turn it to ignition point 2 (so you will need to remove the key part from the fob or use a spare key)
then point the fob at the receiver, near the front interior light, within 10cm or so.
you may need to press just the unlock/lock button or also press the double lock button.
but either way you will know pretty soon if it has worked but turning the ignition off and trying it!
Threads: 11
