Threads: 266
18
Car Model/Spec: 205 DTurbo
Can anyone tell me the size of the nut in the centre of the hub as I'm trying to get drive shaft out of the gearbox for removal.
Biggest I had has 32mm so I'm guessing it's 34/36?
Threads: 87
48
35mm mate . .
Threads: 226
24
Car Model/Spec: A3 TDi
I couldnt even find a 35 in halfords last time! Ended up buy a 36 for 12 f*cking quid!
Threads: 59
3
Car Model/Spec: 306 D-turbo
Or use a blow torch just be careful of melting brake lines and boots
Threads: 57
3
Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
If you have centre less wheels remove the centre cap and slacken the nut with the wheels on the floor
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
They are bloody tight just keep bouncing on the bar it will go eventually. I find afew bounces stood on it works fine. Done several this way
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 226
24
Either you lot have found some seriously tight ones or all the ones i've done have been easy... Or im hench as f*ck? lolz
But being serious i just lean over and pul the bar up towards me and never had an issue :/
Threads: 266
18
My 35mm just slips too much, probably shouldn't have got an impact one.
What's the alternative? Whole Hub off? Trying to get the gearbox out.
