Hub nut size?
Hub nut size?
Can anyone tell me the size of the nut in the centre of the hub as I'm trying to get drive shaft out of the gearbox for removal.
Biggest I had has 32mm so I'm guessing it's 34/36?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
35mm but a 36mm will fit Big Grin
35mm mate . .Smile
I couldnt even find a 35 in halfords last time! Ended up buy a 36 for 12 f*cking quid!
(01-02-2013, 02:08 PM)Tom Wrote: I couldnt even find a 35 in halfords last time! Ended up buy a 36 for 12 f*cking quid!
I did the same. They are a total bitch to crack I welded the socket onto a 3ft bar.
Doesn't feck about now!
Cheers guys!
S14 Zenki Build
Or use a blow torch just be careful of melting brake lines and boots
Bye Bye D-Turbo
I wouldnt even attempt one without a bar! Having someone stand on the brakes tends to help Smile
If you have centre less wheels remove the centre cap and slacken the nut with the wheels on the floor
(01-02-2013, 09:00 PM)swampy Wrote: If you have centre less wheels remove the centre cap and slacken the nut with the wheels on the floor
That is a damn good shout!
They are bloody tight just keep bouncing on the bar it will go eventually. I find afew bounces stood on it works fine. Done several this way
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
We ended up taking whole hub out. Was much easier!
(02-02-2013, 12:42 AM)kentiiboii Wrote: We ended up taking whole hub out. Was much easier!
Just to add to that.... At the time I was 23stone bouncing up and down on mine still didn't budge.
(02-02-2013, 12:18 AM)HDIkyle Wrote: They are bloody tight just keep bouncing on the bar it will go eventually. I find afew bounces stood on it works fine. Done several this way
Spike and I bent a bar like this so resorted to bouncing on my torque wrench - which I promptly broke Sad
Thanks for the vote of confidence fella's. Tongue
S14 Zenki Build
Either you lot have found some seriously tight ones or all the ones i've done have been easy... Or im hench as f*ck? lolz
But being serious i just lean over and pul the bar up towards me and never had an issue :/
My 35mm just slips too much, probably shouldn't have got an impact one.
What's the alternative? Whole Hub off? Trying to get the gearbox out.
S14 Zenki Build
  Top mount intercooler bolt size/ timing hole size LewisG306 2 2,755 13-07-2014, 10:44 AM
Last Post: LewisG306
