Car Model/Spec: 1.9 Non turbo estate
Would anyone be interested in the following I can get them at a discounted price just gauging intrest and then will get a definite price on them if enough are interested
Nnc Laser Door Projection Welcome Lights 12V Plastic Set Of 2 Peugeot Logo New
£29.99
DescriptionDeliveryWarranty & ReturnsAbout Us
Laser Door Projection Welcome Lights.
Set of two Each unit is inserted into the bottom of your car door and wired into the interior light circuit so that when you open your door, the outside floor has the logo beamed down onto it. It looks great and saves you stepping in puddles without seeing them first!
Features:
Working voltage: 12V
Power output: 3W
Working temperature: -40'C~105'C
Life: 30,000-50,000 hours
Diameter: 2.8cm
Lights up like this
Threads: 208
60
Pretty cool. Maybe interested once iv seen on fitted
Threads: 132
Do you do ford my little bro interested
I'm waiting for an e brochure to be forwarded to me from the supplier but I think I can get ford ones
Threads: 171
46
Yes they do it for pretty much any manufacturer
There is a guy that advertises these on a the Facebook groups
Also 29.99 is the retail price of them which is a lot for a bright led with a filter over it lol
I will be getting them cheaper than that I'm just not sure how much cheaper until I have some numbers
Threads: 105
Car Model/Spec: Stage 1 moonstone HDI
id be interested in these, are they hard to install?
No just a hole in the bottom of your door card and positive and negative on your interior light jobs a goodun
Threads: 79
17
Has it not been discussed before that using the interior light as a source of power could damage the ECU? Just something to consider when recommending it thats all.
Threads: 178
28
Car Model/Spec: HDi!
LED's should be fine as they draw less power than a standard bulb anyway
Is anyone interested in these can get these for £18 if definatly interested let me know please
Threads: 183
20
Have you got pictures of these fitted?
Not peugeot but general idea
You have the knowledge to make them work anywhere
