Threads: 465
114
Car Model/Spec: Vauxhall
being able to flash the fog lamps with the main beam,
or high beam with fogs, then off on dip
this seams to be quite a good mod for country road driving.
Ive gone and done the mod myself
on my PH3 HDI and took a few pictures for you people
the fogs are still switched and used as normal but you have the option of fogs on with high beam or fogs on when flash high beam
remember this mod is not legal but with a switch to turn it off you are more in control when it comes MOT time
first off i armed myself with
Diode
switch
heat shrink
wire
electrical tape
soldering iron
and the electrical drawing
and tools
first thing was to work out what i was going to do and where to connect the diode and switch
i decided to do all the connections inside the steering
column cowling
this is a drawing of the additional circuit added
had to remove the cowling to expose the plug on the back of the light stalk
i metered out the cables to work out what was what and working out where to connect my circuit
thin brown wire go's to the headlight high beam
thin red wire go's to the fog lamp relay trigger
stripping back the cables soldering in my new wires and mocking up the install to test
after testing to make sure the diode was the correct way round the circuit was installed and insulated up
once insulated it was time to mount the switch into the cowling
then its a matter of refitting all the cowls
and the final test
Threads: 91
12
Car Model/Spec: 306 D Turbo
Do you know if the wire colours are the same on the phase 1, ie, brown for main beam and red for fog light. I'm guessing that the relay is in the same place for the fogs as I was thinking of tapping in to the back of that to save running cable behind the heater controls etc.
But great write up!
Threads: 23
Bah, all that reading and I forget that my Rallye doesnt have fog lights. Doh!
TEAM TRACK CAR + An E60 530d M-Sport for the daily
Threads: 91
12
Ian Wrote:Bah, all that reading and I forget that my Rallye doesnt have fog lights. Doh!
Propper loled
Threads: 5
What a Fantastic modification, Very useful and well described. I will definately be doing this to my Gti6. I like the switch that you used aswell, it looks factory fitted.
Threads: 15
this is probably a silly question.... but what diode do you use ? :oops: there are loads to choose from !!
Threads: 465
114
Parts used
a small rocker switch
RS Stock No. 278-9733 £0.76p
or
maplin Order Code: N19CL £0.89p
small diode
i used
SKa 1/17
RS Stock No. 505-2977 £0.61p
cant find this one in maplins
but a 1N4001 or 1N4002 or 3/4 will do
maplin Order Code: QL76H £0.24p
the diode is the main part of this mod but aslong as it is a rectifier diode you cant go wrong
Threads: 132
4
Want to do this on phase 1
Is it the same
Threads: 202
58
No because the fog switch is in the centre console. The same principle applies though, I'm sure I saw this done on a phase 1 before.
Threads: 61
4
Given 6 thank(s) in 5 post(s)
principle would just be the same find out what wire triggers the foglight relay and thats it surely??
Threads: 465
114
will work the same if the PH1 has a foglight relay "yes"
just need to trck down the correct wire on the relay
Threads: 162
21
Given 23 thank(s) in 23 post(s)
Nice idea and guide that.
Cully, on the panel with the passenger airbag switch on your car is there a round blank next to it or a lock out switch for the rear windows?
If there is a blank you could replace it with a front fog light switch from a ph1 to activate the new function, this way it'll keep everything looking OEM. It'll also light up with the illumination if wired correctly.
Threads: 142
58
Car Model/Spec: E46 BMW 320d
This is the guide i used when i did both my 1.4 and my DT, love this mod...so simple, and so effective! I'll even rep you for it again cully!
Threads: 476
81
Car Model/Spec: 306 Rallye
(19-01-2013, 12:46 PM)DeeTurbo Wrote: Nice idea and guide that.
yeh i think you can use one of the button switches like this. IIrc it might be the rear window heater switch. Wait for someone else to confirm that though!
Threads: 465
114
he he i have rear lecy windows all the blanks have switches
and thankyou WINgNuTz
Threads: 132
4
if anyone can point me in the direction ofthe wires to use for ph1 would appreciate it
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
You say about the polarity of the diode, is the picture above showing it correctly, with the negative side of the diode going towards the foglight relay?
I plan to do this at the weekend if I get the chance!
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
Threads: 465
114
(29-01-2013, 11:09 AM)C.A.R. Wrote: You say about the polarity of the diode, is the picture above showing it correctly, with the negative side of the diode going towards the foglight relay?
yes picture is wired correct
Threads: 26
Car Model/Spec: ZX Volcane
Very good! Diodes are bringing gcse technology flooding back!
Threads: 236
36
Colour variation on my Y-plate, the high beam wire is grey instead of red...
Works all the same obv.
Threads: 581
195
Has no one realised yet that the colour codes basically mean sod all? Its all done by numbers on pugs
Threads: 465
114
(27-02-2013, 05:37 PM)Niall Wrote: Has no one realised yet that the colour codes basically mean sod all? Its all done by numbers on pugs
yes i know that!
and even the numbers vary between the same year/model
Threads: 476
81
The colours only change now and again though. if youre lucky doing it with colours is really helpful! Especially if your numbers have rubbed off your wires!
Threads: 465
114
thats why i showed the wires at the plug in the original picture
Threads: 198
135
Can this be used to wire up these with main beams..?
Threads: 3
Car Model/Spec: VW Bora
27-02-2013, 09:18 PM
(This post was last modified: 27-02-2013, 09:20 PM by Luhoer.)
works exactly the same, just go to the relay for the new lamps and you're fine
EDIT: if you only want to switch them on together with the main beams you can forget the diode
Threads: 465
114
bumpy bump just for piggy
i have done this mod to my Gti6 too it lights up the road so much more now on a late night Bwarp!
Threads: 591
54
25-02-2014, 03:43 PM
(This post was last modified: 25-02-2014, 03:47 PM by Piggy.)
haha...
I was just reading this through...then spotted your post! haha.
Im not all that lazy Cully
why the need for the diode?? (leccy noob!)
Threads: 581
195
(25-02-2014, 03:43 PM)Piggy Wrote: haha...
Im not all that lazy Cully ![Tongue Tongue](https://www.306oc.co.uk/forum/images/smilies/tongue.png)
If the diode isn't there, when you turn the fog lights on in actual foggy use, it will back feed and turn on the high beam.
Threads: 591
54
(25-02-2014, 04:23 PM)Niall Wrote: (25-02-2014, 03:43 PM)Piggy Wrote: haha...
ahhhhhhh
